Go Back   Home > Forums > General Interest > Car Audio
Old 28th May 2008, 12:55 AM   #1
shagone is offline shagone  United States
Default IRLZ34N in JL 1000/1
i need to replace a IRLZ34N in JL 1000/1 that is shorted. it is not on the sync but near the middle of the board.
is this part of the regulated voltage circuit? what is a good substitute for this part? irfz44n? irf540n? i have both of those available.
the big green bodied resistor near this fet is burned looking to.
Old 28th May 2008, 03:19 AM   #2
If this is the FET near the yellow transformer near the center of the board, yes. It's the power supply for the low voltage circuits.
The L in the part number means that it's a logic level FET and is designed to turn on at a lower gate drive voltage than the Z44 or the 540. They will probably work (Z44 suggested) but they may run hot if the drive IC doesn't have enough drive voltage.
The transformer may be shorted or there may be a shorted component on the secondary side. If you can get to the resistors between the filter caps, you can measure the voltage across them to determine if there is excessive current draw. If there's excessive current draw, one is likely to show signs of overheating.
You also need to confirm that you have a good square wave drive on the gate of the FET. If it's DC or doesn't go to ground, the drive circuit may be damaged.
Best 7.1 Amp for under £1000 martin01p Solid State 1 28th August 2008 02:22 PM
Best $1000 DIY fin1bxn Multi-Way 18 24th January 2007 04:47 AM
Diy Akg 1000 tade Full Range 1 13th May 2006 07:24 AM
1000... Never thought I'd do it. Duo Everything Else 12 22nd July 2005 09:01 PM
Page generated in 0.09644 seconds (59.53% PHP - 40.47% MySQL) with 10 queries
