#11 |
OK, well I guess the problem WAS caused from a solder bridge all along. It was so tiny I didn't notice it at first. I only saw it when I got in real close to desolder the TIP35.
This tiny spec was definitely not from me, so I don't know how sub channel ever worked at all with it being there. The bridge connected the base of one of the TIP35 to the positive rail of the 4-channel amp section power supply. The sub channel appears to be working fine now. There is only 14mv offset on the output. I just need to reconnect the preamp board and run a signal through it now. Thanks again everyone; especially Perry.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#12 |
WOW somebody knows how to use the Macro setting on their camera. Chances are the amp did work fine at one time, It looks a lot like it was mounted to the back of a seat and driven a bit too hard, causing the solder to melt and gravity took it from there.
If it ain't broke Don't fix it |
#13 |
I put everything back together and the sub channel is playing music.
Not a bad little amp for $20. Gotta love DIY repairs. Or maybe it should be called DIYWHFP (do it yourself with help from Perry).
#14 |
Wow, so someone must have tried to repair it before? Glad you got it figured out.
Don't worry... you can always turn the gain down! |
#15 | |
The solder bridge was also making the positive rail of the sub channel supply high at 53v somehow. I had measured this before I found the bridge. Now both rails measure 47v. Next time I try to repair an amp I will be sure to look twice for even the smallest solder bridges.
#16 | |
I agree with Anonymous1, I don't think it has been repaired or attempted before. I am sure that when the bridge was created by the melted solder and the gravity, it took out the TIP36s. Then it became a Sold As-Is Ebay item.
#17 | |
#18 |
Think I saw that amp on there but did not know much about them. The guts look similar to some others I have seen.
I have found a lot of solder bridges in cheap amps that have hand soldering. I swear some of them have a pound of solder on the board. Does not seem like it would have worked with it there when new so something put it there. |
| TIP35C TIP36C for sale | Tom7227 | Parts | 0 | 4th October 2008 09:25 PM |
| Tip35C/Tip36C | Risto80 | Car Audio | 0 | 15th May 2007 09:53 AM |
| Lm3875 + Tip35c/tip36c | JojoD818 | Chip Amps | 31 | 29th December 2003 10:31 AM |
| An amp that uses Tip35c and Tip36c Transistors | Jemplayer | Solid State | 1 | 10th June 2003 12:55 AM |
| Page generated in 0.11587 seconds (75.76% PHP - 24.24% MySQL) with 10 queries |
