I made a tiny chip in the brown coating on a resistor, it is hard to see and is close to the lead.
Is the resistor shot????? |
#2 |
It's probably not anything to be concerned about. Most leaded resistors have metal caps near the leads so you probably didn't damage the resistive element.
Remove one lead from the board (should be able to do it without removing the board) and check it with a meter.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Custom Title
It should be just fine. The coating is just to insulate it, it has no other function.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
| Which resistor type for emitter resistor? | sajti | Parts | 25 | 8th April 2009 06:12 AM |
| Flameproof coating chipped | slowpogo | Parts | 2 | 12th January 2007 12:21 PM |
| Help with Resistor Please | saabie22 | Parts | 5 | 2nd February 2005 09:39 PM |
| screen-plate resistor and grid leak resistor | metebalci | Tubes / Valves | 4 | 26th February 2004 03:18 AM |
| What is the best resistor? | CryingDragon | Solid State | 8 | 9th October 2002 02:38 AM |
| Page generated in 0.06703 seconds (70.01% PHP - 29.99% MySQL) with 10 queries |
