"transformers" inside car amp?? - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 2nd June 2008, 07:01 AM   #21
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
Originally posted by Zero Cool
PS
PC connections would have 2 black wires in the middle. those leads are +12V Ground and the yellow is most likely remote turn on!
NOT pc connections.
And why not? 12v is main voltage, GND, and 5v for remote...everything seems ok to me
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 2nd June 2008, 07:39 AM   #22
Dan2 is offline Dan2  South Africa
would 5v be enough for remote?? i thought it needed 12v
Old 2nd June 2008, 08:03 AM   #23
luka's Avatar
Hi
1v would be enough, you don't drive IC with this voltage, just few transistors that bring 12v to IC and other components...you need only base voltage of transistor so even less then 1v
Well it all depends on what you need, if this amp was made for PC then no, but if for car then it has bigger base resistor or even zener added inside for remote
I FEEL SLOVENIA
Old 3rd June 2008, 01:25 AM   #24
EnvisionAudio's Avatar
Originally posted by luka
Hi
The amplifier pictured is a USA model by Sparkomatic. The company no longer makes car audio equipment, but when it did - it did so for Altec Lansing. Sparkomatic is considered a budget brand. The amplifier shown is not designed for a PC, but a vehicle. I thought it looked like PC connections, but have been corrected - it is simply the input wiring connections.
DCX2496/DEQ2496 Car Audio Conversions
www.envisionelec.net
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
help customize "slow turn-on" duration in this circuit (link to schematics inside) jarthel Power Supplies 10 17th August 2006 07:05 PM
Scavenging transformers to "bridge" Paulr Solid State 0 7th August 2003 11:29 AM
Copyright 1999-2017 diyAudio
