Go Back   Home > Forums > General Interest > Car Audio
Old 8th May 2008, 07:07 AM   #1
Clipped is offline Clipped  Thailand
Send a message via MSN to Clipped
Default relay on radiator fans
i need to wire up my radiator fans directly...because of air conditioning problems.
is the 30 amp bosch relay up to the task of running 2 electric radiator fans?
the stock relay doesnt say how many amps it can handle.
Old 8th May 2008, 07:16 AM   #2
Send a message via AIM to DigitalJunkie
I would probably use 1 relay per fan. The start-up surge of the motors can be fairly high,though it is pretty short.
Old 9th May 2008, 02:16 AM   #3
jol50 is offline jol50  United States
Some cars have multi speed fans, low for AC in traffic and high for when car gets too hot I think it is. If you are into that stuff you can swap one into there. If yours runs real hard when on, they really suck on the alternator if you run them all the time. Or maybe a large resistor of some kind to slow it down.
Old 9th May 2008, 06:01 AM   #4
if the turn on surge of both fans at the same time is a bit much for your electrical system, you can build a simple delay circuit with a resistor, and a cap to delay the second fan until after the first one has started.
If it ain't broke Don't fix it
Old 11th May 2008, 06:21 AM   #5
good ideas... my radiator busted and the fans wouldnt turn on, the culprit was the plugs that actually plug into the fan...so i wired some connectors straigt to the plugs and dropped glue inside the housing to secure it.
but i still went ahead and hard wired a relay to the fans to turn them on...i think i may even have a counterfeit relay... there are two '87' terminals...no 87a...and they both come on at the same time regardless.
right now i have one relay powering both fans but will add another relay just for safety precautions.
Radiohead Fans here? weissi Music 7 10th September 2004 01:08 AM
amp fans sriegel Pass Labs 4 5th January 2002 11:10 PM
Page generated in 0.07582 seconds (69.57% PHP - 30.43% MySQL) with 10 queries
