Go Back   Home > Forums > General Interest > Car Audio
Old 5th May 2008, 01:34 AM   #1
Default Line in directly to stock head unit amp
The stock head unit of my Ford Escape doesn't have any aux inputs, but after some disassembly I found two solder points marked LOUT and ROUT. I'm assuming that these are the left and right outputs for the DAC. What I want to do is solder two wires to somewhere on those 2 traces to feed a line-level signal from my MP3 player directly to the amp built into the head unit.
The problem is I don't know where I would solder the wires. I would just solder at the solder points, but they are after two resistors of 0.82K. Annoyingly, I can't find the datasheet of the DAC so I don't know why these resistors are there.
So my question is, should I solder at the points or on the DAC side of the resistors?
Also, maybe somebody would have more luck in finding the datasheet,I think it's a NEC D63802AGF or 0246K3(515). The part in brackets I'm not too sure of, it's hard to read.
Head unit greg928gts Car Audio 9 10th June 2009 06:26 PM
Upgrade stock head unit amplification IC groover1234 Car Audio 3 8th October 2007 06:09 PM
stock head unit quality? dalcorn Car Audio 1 12th May 2006 03:27 AM
Modifing stock head unit johnm_10 Car Audio 2 7th April 2006 08:54 AM
Aftermarket head, stock amp Thorshavn Car Audio 6 10th June 2004 02:24 AM
Page generated in 0.07577 seconds (68.70% PHP - 31.30% MySQL) with 10 queries
