Help with Rampage AMP-522A? Urgent.
Hello everyone, I have a quick question for those of you who might just happen to have a Rampage (audiovox) AMP-522A layin around.
What is the resistance, or stripe colors, of the resistor at spot R10? Should be right next to a Capacitor labeled C10. Thanks in advance for the help. |
If no one knows the value, trace the connections for the resistor and tell us what each end connects to and provide a photo of the board and we may be able to tell you approximately what it should be. If it's on the primary side of the power supply and it burned beyond recognition, it was probably a relatively low value resistor.
I found it. It was a 2200 ohm resistor.
| All times are GMT. The time now is 01:57 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
