ATOMIC 5000 D Repair urgent please
Old 4th May 2008, 08:21 AM   #1
basswarriors is offline basswarriors  Italy
Default ATOMIC 5000 D Repair urgent please
Boys please help me, am in despair ! I have two atomic 5000 with the same problem, putting in the incoming signal the volume does not get up, at times they come over two minutes and the volume gets up alone, have died electronic, and according to me it is due to the broken entry circuit, you can help me? entering with a signal on input up "input Master " the amplifier works but the outgoing level is obviously low
Old 4th May 2008, 08:40 AM   #2
Perry Babin is offline Perry Babin  United States
If you set the master/slave switch to 'master', set the gain to the maximum and drive the signal into the L/R input RCA jacks, is the speaker output level low?
Old 5th May 2008, 10:04 AM   #3
thanks, of all and excuse me !, are Italian and use a translator, however raising to the maximum the gain, the amplifier distributes little escape, after varies to you second is raised to all power !
Old 6th May 2008, 11:42 PM   #4
jol50 is offline jol50  United States
I assume you have tried other amplifiers or input devices to rule them out as defective?
What is the two minutes, do you mean it works after two minutes?
ATOMIC 5000 D Repair urgent pleaseHide this!Advertise here!
Howabout a DIY atomic clock? Duo Everything Else 31 25th February 2009 04:31 AM
Eltax Atomic 8.2 problem, help! DorinD Subwoofers 1 9th January 2009 02:13 PM
Improve CD playback with an Atomic Clock! rcavictim Swap Meet 0 29th January 2006 05:55 PM
Atomic bombs and decibels. Circlotron Everything Else 33 2nd February 2004 08:02 PM
Copyright ©1999-2017 diyAudio
