Go Back   Home > Forums > General Interest > Car Audio
Old 3rd May 2008, 08:47 AM   #1
vasdef is offline vasdef  United States
Default need advice on system setup
I'll explain my current setup, and ask if theres a better way.
I have a Grand Caravan with a Kenwood kdc-mp522 HU.
2- 6x9's in the dash connected to a 400W Profile amp with a 6" sub and a 10" sub bridged.
2- 6x9's in the doors powered by another Profile 400W amp
Is there a better way to hookup the subs?
Do I need a crossover?
Old 3rd May 2008, 08:54 PM   #2
jol50 is offline jol50  United States
I would recommend you have a sub, or matched subs, on their own amp with a low pass crossover. Crossover can be in HU , amp, or external. With 6x9 you may or may not need a HP crossover, they may be able to run full range unlike smaller speakers. I would HP them anyway just low at 50Hz or something, because it saves amp power. Different subs really should not run same frequencies, different in size or enclosure. Sometimes it will work but often they can cancel each other out at certain frequencies.
Old 5th May 2008, 04:06 AM   #3
ok, thanks for the advice. I did remove the smaller sub and left the 10" one bridged. It seems to sound better.
V
Old 5th May 2008, 03:02 PM   #4
You could run a crossover, just watch the cheap ones they can put noise in the system. Four 6x9 can be a great setup with a sub.
SE setup need amp advice ttruman Multi-Way 10 12th April 2008 05:14 PM
system setup mike49504 Car Audio 5 20th June 2007 03:41 AM
Help and Advice for setup mugglewump Multi-Way 5 10th March 2006 04:26 AM
Help with system setup Steven99 Everything Else 4 22nd December 2005 03:06 PM
DIY System/Setup Names??? 10K2HVN Everything Else 2 13th January 2005 07:14 AM
Page generated in 0.07801 seconds (70.49% PHP - 29.51% MySQL) with 10 queries
