Kicker ZX1000.1 repair
Old 3rd July 2008, 06:14 AM   #91
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
I have done a bit of power testing with the amp.
with a 2 ohm load, with full signal I can send it into slight clipping (afraid to go further as the 8's are going into over excursion). clipping is clean as the tops of the sine wave simply flattens.
I have measured about 1055watts going into 2ohms and that already accounts for the voltage drop of the power cables. the only thing warm was the part of the top plate directly above the output inductor. the main heatsinks are only slightly warm.
Old 3rd July 2008, 06:20 AM   #92
luka is offline luka  Slovenia
luka's Avatar
Hi
NICE! How did you measure power? How's the sound, bass in this case?
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 3rd July 2008, 12:38 PM   #93
I used an oscilloscope on the output terminals with the two 4ohm speakers in parallel. measured peak voltage and calculated rms volts then watts.
I made another vented box tuned a little higher. 1.4cuft 34Hz. my vision blurrs when inside the car. if you didn't know, you'd say I have two 12's at the back.
Old 3rd July 2008, 12:58 PM   #94
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Does it only produce +/-65V peak with 2ohm load? I was expecting more (but it's just a car-audio amplifier). Use a music signal if you weren't doing so.
I use to feel like the small child in The Emperor's New Clothes tale
Old 3rd July 2008, 01:01 PM   #95
yes, I'm using a music signal. I wasn't able to measure the input voltage but I bet it was below 12V or so. my car has a small alternator.
Old 3rd July 2008, 01:15 PM   #96
luka's Avatar
Hi
Note that speakers change their impedance, you sure you really got that power?
You could use small "current" resistor to measure current and voltage after that to get more real power
I FEEL SLOVENIA
Old 3rd July 2008, 01:27 PM   #97
I don't know. I wasn't trying to get the exact output. just a ballpark figure to know how much power there is.
Old 3rd July 2008, 07:42 PM   #98
Eva's Avatar
Originally posted by luka
Hi
When calculating power, nominal impedance is usually taken because this allows to compare amplifiers. Then again, music signal is not a continuous tone and load impedance is strongly frequency dependent. Calculating the actual power involved requires a sophisticated analyzer and the reading would no longer be an indicator of how loud an amplifier can get.
Old 4th July 2008, 03:40 PM   #99
had a trip this afternoon. around an hour with the amp blasting, and same thing when I returned home. amp is still alive.
A/C was off, heatsink is around 45degC (didn't have my thermometer at hand) with minimal cooling.
the amp has more power than I'll ever need so I guess it will last with me.
Old 16th August 2012, 08:50 AM   #100
malvechaitanya is offline malvechaitanya  India
Is there a Service Manual for the ZX1000.1 Amp ?
Anyone Got It ?
Kicker ZX1000.1 repairHide this!Advertise here!
Kicker KX600.4 repair intensem1rider Car Audio 21 5th January 2016 05:54 PM
Kicker KX750.1 Repair Help midnightg35x Car Audio 71 15th April 2012 10:59 PM
Kicker ZR1000 repair help needed KyferEz Car Audio 38 3rd October 2008 04:44 PM
Kicker 500 si stormtrooper Car Audio 0 25th September 2006 01:20 AM
