Go Back   Home > Forums > General Interest > Car Audio
Old 20th April 2008, 06:34 PM   #1
Default Need help - Fet replacement Alpine MRV1505
Hello!
Two of the DC-DC drive Fets is smoked in my Alpine MRV-1505 amp
MTAJ30N06E is the part number.
Cant find this part anywhere, here is a datasheet.
www.itxpress.se/3006.pdf
What Fet could i replace those with? Some IRF maybe?
There must be parts with much better specifications since this
is an quite old amp.
I know to look for Max voltage and Max DC/Peak Current.
What more Important specs should i look at compared from
the datasheet?
Im not so familiar with Fets so some help finding a good
replacement would be nice.
The Fets (6 of them paralelled) are driven by a IC.
Schematic www.itxpress.se/mrv.pdf
The Outputs read OK so i cant get why two of the Drive Fets
smoked, maybe its no fault and they smoked from overheating?
Old 20th April 2008, 06:44 PM   #2
I use IRFIZ44Ns (note the second I) when I need fully encapsulated power supply FETs.
Look for broken solder connections in the drive circuit (IC to FET). Do this for both banks of FETs in the power supply.
Alpine FM reception sigfrid Car Audio 26 18th April 2011 02:07 PM
ALPINE m-bus question phatmanmike Car Audio 3 21st July 2008 04:27 AM
is this an alpine amp? jol50 Car Audio 30 29th April 2008 03:11 AM
Transistor replacement for Alpine F300 spooney Car Audio 7 14th January 2007 12:10 AM
PPI vs. Alpine smokeaway Solid State 2 28th August 2005 10:51 AM
Page generated in 0.06222 seconds (68.07% PHP - 31.93% MySQL) with 10 queries
