Audiobahn A12001DQ thudding
This amp had a blown out the IRFZ44N pieces when i replaced those the amp works great now. My problem is when you take power away from the remote turn on wire the subs put out a loud quick thud or pop. What would cause something like this to happen? is it in the power or preamp section of the amp and what should i do to fix it?
did it do that before you replaced those other parts??
usually the thud is the power supply caps discharging, and the quickest way to get rid of that is hooking a relay up between the amp output and the speaker, and hook that up to the remote wire (if its a 12V relay)
look around in the car audio section - there's more info there
Generally, the muting circuit prevents the amp from popping. Many of the class D amps use relays for muting. If this amp uses a relay and the relay isn't opening quickly enough, that could cause the amp to pop.
You can hear most relays click when they open and close. The relay should click approximately 5 seconds after remote voltage is applied and should click as soon as you remove remote voltage (no delay). If it isn't clicking as soon as you remove remote voltage, the drive circuit for the relay is likely damaged.
It's the black box in the corner in the photo below.
The drive circuits vary. If there's a diode near the relay, it's likely across the relay coil. You can measure the voltage across the diode to determine if the voltage is being switched on/off as it should be.
You need to check your driver board to see if it's become conductive. The easiest way to check this is by shining a bright light from the back of the board. In the image below (link) you can see how the area between the solder pads has become blackened. You can't generally see this from the outside. You have to use the light so you can see the inside of the board.
Does your board have the darkened area shown in the image?
http://www.bcae1.com/temp/cuttraceondriverboard.jpg
If you pull the driver board, power it up to see if it still pops when powering down.
Remember... Have the transistors clamped to the sink and have a relatively small fuse in the power line when testing.
Do you have an oscilloscope?
I doubt that anything near the FETs would cause it to pop when powering down. Which diode is it?
In the audio section, there are diodes near each of the outputs. In the power supply, there should be 2 diodes per bank/group of FETs. Those diodes are not likely to cause the output to pop when the amp powers down.
If you had a scope, you'd need to check to see how quickly the voltage on the drive-enable pin transistions from low to high when the amp shuts down. You may be able to see it if your meter responds quickly enough. The pin is #6 on the driver board counting from the RCA end of the amp. The voltage will be ~80v while the amp is muted and very near 0v when the amp is not muted. To prevent popping, the amp should mute instantly when the remote voltage is removed.
Have you removed the driver board yet? If not, check this first.
Recheck it one more time.
When the amp initially powers up, the voltage will rise with the rail voltage. After the mute delay (red light goes out), the voltage will drop to 0.2v (approximately).
When the remote voltage is removed, the voltage will 'instantly' go back to rail voltage. Since the rail voltage will begin to drop as soon as the remote voltage is removed, you have to read the voltage as quickly as possible (have meter connected while disconnecting the remote).
Reading it like this, does the voltage only go up to 8.6v when the remote is disconnected?
Also, confirm that it's near rail voltage (~80v) before the red LED goes off.
