need help to repair pg R9.0.5
Old 19th April 2008, 03:08 AM   #1
xxxwhezzy is offline xxxwhezzy  United States
Default need help to repair pg R9.0.5
just found this forum so big noob here. my amp only has sound through the hi channel but none through the bass. i did burned the amp couple months ago and try to repair it. i had my cousin replace some of the resistors and transistors that were brunt r cracked, but it still didnt work. i did search through the forum but didnt find nebody with the same problem. if u guys need me to post pictures i will, but the amp is still mount in my car. dont feel like taking it apart.
Old 19th April 2008, 03:34 AM   #2
1moreamp is offline 1moreamp  United States
without knowing what parts you have replaced any one here capable of helping you will be at a loss as to where to start. The amp will have to come out to be repaired anyway, Just something to think about
Old 20th April 2008, 03:52 AM   #3
the transitors i brought from digikey is FQP50N06
the resistors are .25 watts carbon film
i circled the ones i replaced
Old 20th April 2008, 03:52 AM   #4
broken link my bad
Old 20th April 2008, 04:12 AM   #5
damn how u post pic?
Old 20th April 2008, 04:14 AM   #6
None of your links are working it seems, But I can tell you by the part number you replaced the power supply Fets, and there gate resistors.
This is a symptom repair you performed, I am fairly sure the sub channel is toast also. bass channel power supply's don't usually fail by themselves. They usually fail after the sub outputs are shorted.
So there was more wrong then was openly visible. PG lists a flat repair rate of $150.00 for this amp if your in the USA. The outputs are TIP-35 and TIP-36, you should check these out for shorted condition before trying to repair the power supply.
See if you can get your links to work, so I might see your previous work....
Old 20th April 2008, 04:20 AM   #7
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I have fixed your links... you need to use the img tags -- html won't work
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th April 2008, 04:41 AM   #8
OK lets get started...
Q9 thru Q16 are the four channel power supply mosfets. Your repair looks ro have worked to get the amp back running, but you said there were bad channels, could you give me more info like Rear channels maybe ?
If this is correct you must ohm out the outputs for the bad channels....LMK...Please tell me the Q numbers by the devices you replaced, so I can locate which power supply you repaired??? THX
Old 20th April 2008, 05:20 AM   #9
the 4 channel never went out only the sub channel. i'm reading through the wiki right now to see what u mean by the Q numbers, im not a electrician r nething so bare with me. if the repair cost $150 then its not really worth it because i only got the amp for 125 new
Old 20th April 2008, 05:21 AM   #10
one more thing i did ran an 8 ohm sub to the sub channels n it started smoking, but i had another pg amp with the same setup and it never burned. well i replaced q16, q28, q29, q30, and q31.
need help to repair pg R9.0.5Hide this!Advertise here!
DHD should repair? Solosound Car Audio 5 9th November 2008 07:39 PM
my amp repair benlebow Car Audio 3 10th February 2008 12:30 AM
Nad 304 repair big jim Solid State 0 30th December 2006 11:19 AM
CDM 9/44 to repair CDM 9 Pro Duson Digital Source 1 12th October 2005 04:41 PM
Help for repair my KSA 100 Alex helge Solid State 76 23rd October 2003 03:38 PM
Copyright ©1999-2017 diyAudio
