Hello, the goal of this is to build a car amp as cheaply and easily as possible, while still providing decent power to satisfy the average person.
![]() Approx 150W-300W RMS total in stereo is the goal, although actual wattage isn't a major concern. A younger friend of mine is interested in me building a car amp for him, but he's not spending huge cash on a system, but still wants good sound that's loud. I also want to make some money on such a project, the other reason to go cheap. I found some large efficient heatsinks for only $20 a piece, so to keep it cheap and simple, I want to build the whole amp & SMPS as a whole on only one heatsink and circuit board I don't need to build the amp as beefy as a regular overbuilt DIY amp I'd build myself, I just want it to perform with minimal parts, and be easy to build, and also repair if needed. I had a few ideas: 1. Single pair of MOSFETS for SMPS 75N06 or similar. (75A) 2. Two audio channels rated @ 2 ohm each using a single pair of NJL0281/0302 thermaltrak to reduce usual costs and complexity of using a VBE transistor and mounting to heatsink for temp comp 3. Use SMPS transformer from old recycled computer power supply, and use in reverse as stepup (worked great on an SMPS I just made so far) to get amps voltage rails. 4. Use a few small cheap capacitors in parallel, or just use a single pair of larger caps for the power supply 5. Use TL494 PWM IC with a socket for easy & fast replacement if IC blows, and no voltage regulation, and simple 2N3904/3906 totem poles to drive the mosfets from IC 6. No snubbers on SMPS to save space and cost since they are not necessary for operation What ideas/components, placement, etc, would you recommend in the building of a cheap DIY amp????
#2 |
Here is an option for a small TL494 supply (if you plan to build your own)......
http://www.electronics-lab.com/projects/automotive/012/
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#3 |
Why not find a commercially available amp (used) that's relatively good quality as is and tweak it. You'd have the sink, board, transformer/core and virtually all of the other parts you'd need.
The class B amps (most of the budget amps) have little or no bias compensation so they shouldn't present any problems if you want to use those transistors.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#4 | |
I still want to see if the DIY is possible being I have most of the parts, but don't want to use all my good parts because I will build other things too. No paralleling with the transistors, and using single pairs gets a working amp with mimimal complication and parts. I also thought about just using a single pair of 6800uf capactors for the amps power. 2 caps makes things easy. I remember an old BOSS 250W max amp I fixed a long while back had only one pair of transistors for the SMPS, and each channel, and a simple TL494 with two pull-down PNP's. However, the amp was built with cheap sucky transistors, and weak mosfets. I figured I could try and build a better cheap design of my own, by using much better transistors, that's even simpler in circuit complexity and more reliable than something like that old cheap BOSS. |
#5 |
Last week I bought a made-in-USA Rockford-Fosgate 4 channel amp for $44. The case was a bit corroded, but the innards look fine and unmolested, and it works. Not the kind of deal I come across regularly, but I was holding out for something "nicer" than average, and that sure qualified.
While I'm sure it would be a great learning experience to build an amp, in terms of the time and money cost you'd be better off trolling pawnshops and yard sales for a good used amp. Or just buying something new off eBay or some online megastore, if you can figure out which ones are worth owning. |
#6 |
I bought a 2x200/1x500rms at 4ohm insignia for <40 TMD. It was an unused return (new) and tested, even fan cooled. Just happened upon a good auction. It is huge though and unless a friend of mine wants it not sure what I will do with it. I'm sure some people here have old amps around for that. I might have one soon that is 360x1rms insignia with bad outputs, case is beat up some but fan cooled also.
| Cheap simple class D amp circuit to build. | guitar_joe | Class D | 242 | 13th May 2012 08:57 PM |
| NAD 3020 with loud hum. A couple of simple questions. | KingOfMyCastle | Solid State | 14 | 23rd January 2012 01:04 AM |
| Want knwo how to build hipower amps and loud speakers | audiocrazy_pune | Solid State | 0 | 25th August 2004 03:31 PM |
| Simple and cheap | sparkle | Solid State | 33 | 14th May 2004 05:19 PM |
| Page generated in 0.09134 seconds (79.46% PHP - 20.54% MySQL) with 10 queries |
