here are some pics of the amp in question: http://www.putfile.com/album/185437
the board looks almost identical to the rockford fosgate 360a2 on the ampguts site . The heatsink is different on mine and it looks like at one time it had a top mounted power indicator LED.Is this amp perhaps just a new version of the 360a2?There is nothing I can find on the amp at all to indicate what model number it is.I'd like to find some more info about this amp but its kind of hard when I don't really know what it is.any help would be greatly appreciated. |
#2 |
It is either a 401S or a 301S notice the similarity to the 500S on ampguts. I am leaning more towards the 401S.
If it ain't broke Don't fix it |
#3 |
I googled 360.2(instead of 360a2) for the heck of it and from the pics I saw thats what it looks to be.
#4 |
The 401 is grey in color and the 360 is black. appears to be the only difference.
#5 |
I also found a mystery RF amp but its a baby one. It is an 2.3 I think or maybe Z.3, bright red sink on one end & bottom with a silver square cover over the rest with texture stamped in the top. I think 2x30w and is dated on board 1998 IIRC. Need to find outputs for it or replacements, nobody seemed to have them. Only 4 TO220s. Could not find manual at RF. Lots of SMD inside, only about 4x5" or so.
#6 |
#7 |
Lol, I thought I looked on there! Must have missed it. Yes it is about exactly half that. If you cut the right channels off and made the PS a little smaller that would be it. I thought it might be good for tweeters or who knows. I did not know if it was a typical RF amp and under rated or not, or a cheap line? I think it is bridgeable but says nothing on it.
#8 |
Yes it was a short run of their cheaper line. It is bridgeable into a 4 ohm load. Left positive and right negative, are the bridge terminals. I think they had special parts with rockford numbers on them. IRF-540 and IRF-9540 were suitable replacements. I do not remember if this amp had 4 N channel FETs or if there were 2 P channels and 2 N channels.
#9 |
I dug it out, each channel has a P12P10 and a 36N06V. PS has two 36N06V. It runs and has rail voltage on right channel so I was going to put outputs in it. The P transistors must be RF parts I can't find, the 36n06v comes up IRFZ44E I think as a replacement if I wrote it down right. I also wrote down STP 36NE06. It says made in USA 5/8/96 and rail caps are nichicon 105C 2200uf 25v. According to that ampguts it would be 120w x 1 bridged, nice if I had two and they sounded good and it actually put out 100wrms or so. I think my alpine 2x30 is 90 bridged.
It does not look like anything has been soldered on board, but did have sink grease all over the sink clips. |
#10 | |
Funny! i just repaired and sold one of those. mine had bad power supply fets. Nice sounding little amp! it isn't much to look at but perfect to throw onder a seat to run some highs. here is a link to the manual: http://www.rockfordfosgate.com/libra...x-4_6x-man.pdf whats cool is that it gives you component values to modify the crossover cards to whatever you need. i just sold a rare 5-channel model like this too and the guy that got it is very happy with it. he has it on 4 infinity door speakers and a kicker comp 12" sub. again, a bit ugly but great sound. the plug in cards versus potentiometers for crossovers might have something to do with that? |
| little 6.5 mystery ... | oface | Full Range | 6 | 4th November 2007 11:20 PM |
| Transformer - mystery VA | seventenths | Power Supplies | 10 | 5th September 2007 05:47 PM |
| Mystery woofers | Doug | Multi-Way | 5 | 2nd September 2007 02:15 AM |
| Mystery SE OPT | alexmoose | Tubes / Valves | 4 | 11th July 2006 01:29 AM |
| mystery... | mista2 | Multi-Way | 1 | 14th January 2005 04:20 AM |
| Page generated in 0.10482 seconds (80.44% PHP - 19.56% MySQL) with 10 queries |
