#11 |
Run a 60-100Hz test tone into the amp and measure the AC voltage from pin 1 to pin 7 on the 8 pin op-amp that's in the center of the audio output section.
Also measure the AC voltage from each of those pins to the RCA shield (black lead on shield and red lead on each of the pins - 1 and 7). Check it without a speaker connected and use enough signal level to get at least 1v on the individual pins of the op-amp. If I'm not mistaken, you should get 2x the voltage when measuring across the terminals. The secondary center-tap on this amp is where the windings go into the board just behind the two large filter capacitors. The trace goes over to the 4 center terminals on the vertical jumper board. All points connected to that trace should read 0 ohms to the shield ground.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#12 |
Perry, I am going to take some time tonight to set up a more functional test bench. I am working on the floor of my spare bedroom. I need more light and space now.
Ill also dig out my CD with test tones on it tonight. It may be tomorrow by the time I find it. Evan Also, I wanted to thank you for your excellent site. What a resource! I am reading the entire thing.
Yeah... it seemed like a good idea at the time. |
| hifonics viii bridged mono? rca q... | marko | Car Audio | 4 | 27th February 2009 05:10 PM |
| Original Aleph 3 can be bridged into mono amp? | Pass lover | Pass Labs | 9 | 24th December 2007 11:59 PM |
| SI T-AMP mono bridged? | SatChitAnanda | Class D | 5 | 13th July 2005 07:43 PM |
| A question on Bridged Mono | dar1us | Solid State | 7 | 18th November 2004 02:14 AM |
| Page generated in 0.06018 seconds (69.01% PHP - 30.99% MySQL) with 10 queries |
