LP1502iq - bridge (?) to be replaced
Old 29th March 2008, 07:07 PM   #11
manina is offline manina  Germany
Originally posted by DCPreamp
If the amp works, then don't worry about the rectifiers.
<cut>
I'll see if I can post the 952 schematics later. I just replied to a post on a 2002 amp in this forum a bit earlier.
Actually, the amp does not work at its best. When I turn it on, it has a metallic sound
however after 10-15 minute of work it sounds as it should be.
I targeted the rectifier hoping it was it as it' a pretty easy job to replace this one but if you say it' either working or not, I have to come back to the first option: caps to be replaced
If you have also the 5002iq schematic will ge great
Old 30th March 2008, 05:43 AM   #12
shagone is offline shagone  United States
maybe if you simply replace most of the larger electrolytic capacitors and resolder any bad looking connections it would come back to life. it's worth a shot!
Old 1st April 2008, 05:54 AM   #13
DCPreamp is offline DCPreamp  United States
DCPreamp's Avatar
Here are the 1502 amplifier schematics. The power supply will follow.
As far as the "metal" sound, I'd need to see the waveforms to diagnose it. I still don't think it's the rectifiers, and doubt it's the caps either. It may be the bias circuit: It could be running a real harsh class 'B' until the amp warms up to A/B.
"Believers cling to the myth despite the evidence, reinterpret the myth to suit the evidence, or lie about the evidence to support the myth." "To err is human; to blame errors on external factors is even more so."
Old 1st April 2008, 05:56 AM   #14
DCPreamp's Avatar
Power supply schematics.
Old 1st April 2008, 01:23 PM   #15
Thanks for the PDF (all you posted ).
I'm not able to provide the waveforms - don't have the equipment for this.
As long as it's a matter of replacing caps I can do it by myslef - I'll have to find a good technician to adjust the bias.
Old 3rd January 2009, 01:42 PM   #16
Default work almost done
It has been a while since the last post. I finally managed to have time to work on this amp
Changed all electrolites caps, fixed some soldering (especially at the rele side) and changed the power cables with longer/bigger ones.
I also moved the trimmer to regulate the polarization and finally the amp works great.
How can I fine tune the polarization? I did it "by ears" - slighlty turned untill it sounded better hower I understand this is not the best method; any suggestion?
LP1502iq - bridge (?) to be replacedHide this!Advertise here!
just replaced bridge in Aleph 30 now problem KevinLee Pass Labs 4 28th December 2008 12:57 PM
capacitors need to be replaced? anton Parts 2 1st December 2007 02:00 PM
Two oscillators replaced by one? Ola Digital Source 2 2nd June 2004 08:44 PM
can be MJE2955 be replaced??! nbcd Solid State 1 6th November 2003 08:06 PM
How i replaced my dust cap... Vol 1 speekergeek Multi-Way 10 31st October 2003 04:20 AM
