#141 |
I just replaced it. Same scenario, it heats up to 105 degrees F.
#142 |
I don't know what else you can do. The 5532s run hot but they shouldn't run that hot. It may survive as it is.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#143 |
Ok, well i'll run it hard and see what happens. Im crossing my fingers that either it will be fine, or if there is something else wrong that's causing the current draw/opamp temps, then then I hope that part will blow so I can find it
![]() Thanks for your help! |
#144 |
Im having problem on my MTX TA7801 which the amp has no problem hitting the bass out but once I turn off the REM, it start to discharge and making some noise to my woofer.
I've been troubleshooting it for couple of month but still can solve it. Anyone here can help? |
#145 |
If you disconnect the RCA cables from the amp, does it make the same noise?
#146 |
Yup. Disconnected the RCA also produce some noice when turnning off. I have try to change the processor board from other TA amp. The result also the same.
Currently, im trying to check is there a discharge circuit for this amp. Will there be possible also the JFET controlled the Optocouple failed? Ahhh...so many possiblity which I don't know where to start.
#147 |
The JFET isn't likely defective.
Does LED400 go off immediately when the remote voltage is removed?
#148 |
Yes. LED400 light when normal operation....and imeadiate OFF when remote turn ON is removed.
#149 |
I have a MTX TA7801 that doesn't work have fets 104,106,108,110,112 all burned beyond idenification as well as FETS 103,105,107,109, and 111 broken in half but appear to be a marked n520ak. Does anyone know what these fets are and where I could purchase them?
#150 |
There should be other numbers on the FETs. Start a new thread and post the other numbers on the FET.
There will be no more replies to this in 'this' thread.
| DHD should repair? | Solosound | Car Audio | 5 | 9th November 2008 07:39 PM |
| my amp repair | benlebow | Car Audio | 3 | 10th February 2008 12:30 AM |
| Nad 304 repair | big jim | Solid State | 0 | 30th December 2006 11:19 AM |
| amp repair | KEEBIE | Car Audio | 2 | 31st October 2006 04:48 PM |
| Help for repair my KSA 100 | Alex helge | Solid State | 76 | 23rd October 2003 03:38 PM |
