Go Back   Home > Forums > General Interest > Car Audio
Old 1st March 2009, 09:20 PM   #111
You can't use a zener that's the same voltage as the regulator. For a 15v reg, you need to use a 18v zener. I'm assuming that the 3w zener is across the output of the regulator.
If the op-amps are running too hot to touch and the voltage from pin 4 to pin 8 (for 8 pin op-amps) is less than ~32v, they are likely defective.
Old 1st March 2009, 11:48 PM   #112
Well I am getting 30.8V on pin 4-8 on both op amps, is that close enough to say they are good? I just replaced them today.
I have done some poking around looking for high voltage drops across resistors and the only one I have found so far that's a big drop is R421 near the 3120's with a 20+ voltage drop, however, the resistor is still good at 2k.
I'm going to keep poking around to see what I can find wrong.
Old 2nd March 2009, 08:05 AM   #113
After replacing the op-amps, are they still getting too hot to touch?
I have R421 as a 10k resistor. 20v across a 10k ohm resistor that size is OK.
Old 2nd March 2009, 05:09 PM   #114
Yeah, the Servo op amp is too hot to touch, I replaced it again with another one, same thing, still running too hot. I checked R421, it is 10k, I made a mistake, I thought it was a 2k I replaced.
I have the following readings on the opamps with the x-over board disconnected and the jumpers in place.
Servo
1= -7.08
2= -0.001
3= -0.001
4= -15.12
5= -6.92
6= -6.88
7= -0.018
8= +15.90
Input
1= 0
2= 0
3= -0.001
4= -15.12
5= -0.001
6= -0.000
7= -0.001
8= +15.90
The pin 1 output on the input opamp has my mind a little boggled. But on the servo opamp, with the inputs on 2-3 and 5-6 the outputs are the right polarity, but not +-Vcc like I would expect on an out of circuit test.
Old 2nd March 2009, 05:16 PM   #115
The op-amp seems to be OK. Do you have any DC on the speaker terminals?
Old 2nd March 2009, 05:51 PM   #116
No, theres no significant DC on the outputs, it's in the 10 milli-volts range
Old 2nd March 2009, 06:03 PM   #117
You stated that the amp was up and running. Is it producing output? Sometimes, if the amp is muted, that op-amp will run hot. If it's producing audio, it's not being muted.
The voltages you posted are very close to what I'd expect.
Old 2nd March 2009, 06:15 PM   #118
When I took those numbers the amp was muted, but when playing audio through it to a 4ohm load the servo op-amp was reaching 160-170 degrees, that concerned me.
Would it be safe to say that I can run the amp through some high output tests? I bought the amp off the customer for relatively cheap and gave him a deal on a new amp so that way I can hopefully get this up and running properly this time and sell it.
Old 11th March 2009, 08:14 PM   #119
What would you consider excessive idle current?
With no input to the amp, but the amp turned on it is pulling 5 Amps. Is that excessive? Or normal for an amp this size?
Old 11th March 2009, 09:37 PM   #120
I would consider that excessive. I would expect 2 amps or less. If you power it up and let it idle, do you find that one particular area of the heatsink gets hot faster than the rest?
DHD should repair? Solosound Car Audio 5 9th November 2008 07:39 PM
my amp repair benlebow Car Audio 3 10th February 2008 12:30 AM
Nad 304 repair big jim Solid State 0 30th December 2006 11:19 AM
amp repair KEEBIE Car Audio 2 31st October 2006 04:48 PM
Help for repair my KSA 100 Alex helge Solid State 76 23rd October 2003 03:38 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
