Go Back   Home > Forums > General Interest > Car Audio
Old 16th March 2008, 05:47 PM   #21
jol50 is offline jol50  United States
Colored transistors....come on, just think of how many amps pyramid or audiobahn (/etc bling type amps) would sell if they had LEDs in the transistors that lit up with higher voltage! Could make them clear with maybe three colors to start....lol! I could make millions on those....
Old 16th March 2008, 06:28 PM   #22
Clipped is offline Clipped  Thailand
Send a message via MSN to Clipped
theres a big difference between 90 degrees celsius and 90 degrees fahrenheit...
big fat chrome emitter resistors would be dope...especially if they were wirewound and were mini LEDS spiralling around the wirewound part...dancing to the beat of course...id buy em in a pulse width modulated second.
Old 16th March 2008, 06:42 PM   #23
Go one better and figure out mounting, maybe a screw in each side like a TO3....or notches for a spring clip/etc so you can see the light show!! Then you would need some mosfets to match...hey why not make a big driver transistor with lots of lights for OEM, lol. Then put a mirror finish on the tops of them like cool shades use, so when off they are mirrored or pearl colored.
I think I've seen the green ones in HK amps.
Old 16th March 2008, 07:24 PM   #24
Jonny Hotnuts's Avatar
Black dissipates heat better. Chrome would look cool but chrome (and gold plating) retains heat.
If you solder jumpers on the t03s legs you could mount them on a sink of any thickness.
Just to screw around, after I got a little SS d100 (series 1) I thought it would be cool to reproduce the little Pass amp using a better PS and T03s.
Old 16th March 2008, 07:29 PM   #25
Juergen Knoop's Avatar
isn't that called a tube?
Old 16th March 2008, 07:48 PM   #26
Lol, but that is one boring color.....we are moving into the 21st century here! Blinking lights make it go louder right? It will be like powerbooster lights all over again but they will be in the trunk.
Old 17th March 2008, 01:06 AM   #27
you failed to mention that blinking lights will also make your car go faster as well.
Old 18th March 2008, 04:38 PM   #28
ppia600 is offline ppia600  United States
/\ No, that would be the huge spoilers that increase hp, lol.
Don't worry... you can always turn the gain down!
Old 18th March 2008, 04:43 PM   #29
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
you also forgot to mention, stickers in every square inch of the car.
Old 20th March 2008, 07:07 PM   #30
wg_ski is offline wg_ski  United States
Originally posted by EWorkshop1708
Why don't they just make a flat-metal transistor with 3 leads coming out the top??? Like TO-3, but rectangle, and the leads in a much better place.
They do. And it's only used for low-speed power switching devices like Triacs, IGBTs and some hexfets and rectifiers. Package parasitics are much worse than on typical plastic packages so they don't put the fast stuff in them.
But it sure would be nice to get MJ2119x's in those.
B&C Sub, ATI case ShinOBIWAN Swap Meet 2 15th October 2006 10:34 PM
What to use for a case ???? la9 Chip Amps 3 22nd August 2004 04:34 AM
DIY Case dhole Pass Labs 9 15th August 2004 03:47 PM
case theChris Parts 2 8th February 2003 09:08 PM
Page generated in 0.10797 seconds (77.81% PHP - 22.19% MySQL) with 11 queries
