Orion speaker plug
Orion speaker plug
Old 23rd August 2008, 04:08 AM   #11
memtek74 is offline memtek74  Canada
thank's for responding so quick,ill post a pic and then go from there,i know i'll need a few things to get it back to original state.guess ill have to find a shop local to me to get the fine details done,but again thanks for the replies.
Old 23rd August 2008, 06:05 AM   #12
Perry Babin is offline Perry Babin  United States
If you intend to use this amp, you should be VERY careful when making the connections to B+ and ground. When tightening the screws, tiny wire strands often break loose. One tiny strand can do SIGNIFICANT damage to the amplifier.
I'd suggest blocking the back of the terminal block off with heavy weatherstripping and using dielectric grease on the wire to hold any loose strands.
If you're going to have someone replace the speaker wires in the board, they should try to do it without removing the board from the sink. Sometimes the transistors stick to the insulators and break when trying to break them free. This can be very expensive to repair (if you're going to pay a shop to do it).
Orion speaker plugHide this!Advertise here!
orion DIN plug balanced? Clipped Car Audio 3 24th January 2008 06:33 PM
soldering hifi speaker cable into 1/4 plug saifq Multi-Way 3 19th June 2005 08:48 PM
Vintage speaker screw outs to 1/4" plug JayGee Tubes / Valves 1 6th May 2005 10:45 PM
Siegfried Linkwitz's new speaker, the Orion! Oz_Audio Multi-Way 5 1st September 2002 05:21 AM
