Go Back   Home > Forums > General Interest > Car Audio
Old 3rd March 2008, 06:17 AM   #1
Default Power Acoustik Amp
Hello all.. I'm having a problem with an amp that my brother has had for quite a few years... he only used it for about a year and never abused it. Then one day it just stopped working.. All it does is moves sub back and forth at a slow rate even when not hooked to rca jacks. When it does this it draws a lot of power from the power source and the red led light on the board stays lite the whole time and blinks with the draw of power. All wiring is hooked up right. I was wondering if someone had this problem before and how it fix it. Its a Power Acoustik Fire & Ice FI2X-1600 amp.
Old 3rd March 2008, 09:23 AM   #2
If it draws excessive current with only B+, ground and remote connected, it probably has shorted output transistors.
If this is one of the amps that has two blue boxes inside the amp and the large one says 'high voltage', be careful handling the small blue box. It's the one with high voltage.
Old 3rd March 2008, 05:49 PM   #3
Yes this does have a box that says high voltage on it. it plugs into the other part of the circuit board from the left hand side. Is there anyway that I can test the transistors or anywhere I can buy them from like a radio shack or something?
Old 3rd March 2008, 07:11 PM   #4
jol50 is offline jol50  United States
Let it sit for a while unhooked, then take a meter at voltage and check around for power on the rails and transistors before you work in it.
Generally you take the clamp(s) off to get the part number on them, and test between the legs to see if they are shorted with an ohm meter on ohms test. It may have two different types of transistors on outputs; look at board and see what ones are powered via common source they should be the same, ie: find ones that typically will have middle or right legs connected in parallel. Usually there is two groups per channel, and they may or may not be the same part. If any one is shorted between legs it is bad and may short the rest in parallel.
Get the part number and then figure out where to get them. I have not seen one of these but Perry likely has.
Old 4th March 2008, 05:08 AM   #5
ppia600 is offline ppia600  United States
Isn't that box just to run the indiglo or bling bling neon in the amp? Can it just be unplugged on the low voltage input side of the box? Just wondering, I remember pulling a few of them apart a few years back and they had that box.
Don't worry... you can always turn the gain down!
Old 4th March 2008, 05:31 AM   #6
Yes. On all of the fire and ice amps that I've seen, the high voltage supply (used to power the neon tube) could be unplugged from the main board. It should be unplugged from the main board as soon as the cover is removed.
Old 4th March 2008, 07:43 AM   #7
I already unplgged that box the the neon and the neon itself when i pulled the cover off.. I don't want to seem like an idiot but the trans your talking about is the yellow round thing at the bottom of the attached pic from perry? I'm no electronics expert by far but I know basic 12v circuits pretty well and obviously know how to check resistance in circuits.
Old 4th March 2008, 08:07 AM   #8
The yellow component in the photo is an inductor. The transformer will be larger and the core will be parallel to the board instead of perpendicular to the board.
What have you checked so far?
Have you found any defective components?
If you're unfamiliar with the terminology and the various components, take a quick look at the basic repair page (link in sig file below).
Old 6th March 2008, 07:19 AM   #9
I've looked over your link and understand somewhat what most the parts do... I had to use a headlight to keep from blowing the fuses. I checked voltage between the outside prongs on the transistors for the power side i believe.. I got 1.95 volts when the input voltage to the amp was around 6 volts because of the headlight resisting... I also just the resistence in the same ones and didn't find any that seemed to be shorted. Is there a order of things to check to find the problem or is it just a guessing thing with it?
I also checked the transistors or whatever they are on the other end of the amp and noticed on 2 of them that they seemed to be connected on the outer 2 prongs.???? Just let me know with any help you can... thanks
Old 6th March 2008, 07:19 AM   #10
here are some pics
power acoustik TS-620-2 scampo77 Car Audio 25 12th July 2009 06:03 PM
Power Acoustik Amp Help 22chet Car Audio 7 22nd February 2009 10:05 AM
Need Help With Power Acoustik LT-980/2 Amp FallenOne Car Audio 22 6th October 2008 04:29 AM
Help me to fix POWER ACOUSTIK please! Mordor Car Audio 10 13th February 2006 07:58 AM
Power Acoustik MOFO-10 Sub subwo1 Car Audio 1 24th October 2003 08:12 AM
Page generated in 0.11064 seconds (78.53% PHP - 21.47% MySQL) with 11 queries
