in need of some PPI ceramic driver modules
Old 21st February 2008, 07:44 AM   #1
bayiganteng is offline bayiganteng  Indonesia
Default in need of some PPI ceramic driver modules
3 days ago, I've been given 3 PPI art series amps, and they are:
1 A600.2
1 A600, and
1 AX400
However, I noticed that the ceramic driver modules are all MISSING!!
I want to revive them and need 6 driver modules.
Can anyone help me??
Old 21st February 2008, 09:24 AM   #2
Correction!!
I need 8 modules......
Old 21st February 2008, 03:54 PM   #3
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
same problem here..... for a PC2100 amp.
if all else fails, anyone got a schematic of the driver cards?
Old 21st February 2008, 06:19 PM   #4
Perry Babin is offline Perry Babin  United States
1moreamp had some (if I'm not mistaken) and there was another supplier in Asia. He's the one who posted the following schematic.
http://www.diyaudio.com/forums/attac...amp=1170949161
Old 21st February 2008, 06:27 PM   #5
1moreamp is offline 1moreamp  United States
Well hello boys.. I hear your having problems with itty bitty ceramic cards???
In most cases all you need to do is resolder each contact on these and they will be repaired. PPI had heat issues with these, and they tend to desolder themselves.
Now there are some secrets here:
1: do NOT use flux of any kind it attacks the pad material and the pad will never take solder again.
2: all the devices on these are commonly available, and unless your thick film resistors on the ceramic background are burnt the replacement of bad devices is a option. I have done this and it works but it takes time and patience.
3: careful about how much heat and for how long. it should just be a touch up nothing drastic involved with heat and time.
Now if you are still in need, perhaps I can get some of these below out of the build shop for you, but time is a issue here..
Old 21st February 2008, 07:45 PM   #6
shagone is offline shagone  United States
i know this is a bit off topic but not too far off. i have an original Punch 45HD amp that is only putting out sound on one channel. the channel that is not putting out sound has a ceramic driver board that is getting very hot, i mean very hot! does anyone know where i can find one of these cards or does anyone think that touching up the solder points will fix the problem? there are no burned looking components and i have tested some parts on the ceramic card but not all of them yet. so far they check ok but i have a few more parts to check. any advice would help as these are neat little amps.
Old 21st February 2008, 08:18 PM   #7
Contact this ebay seller for the cards.
http://search.ebay.com/_W0QQsassZdealsbyjason
The preamp/input card had a lot of problems due to leaking capacitors. Unless there was a problem with the outputs, the other cards didn't have too many problems other than broken connections on the pins (where they clipped onto the board). Use silver solder to resolder them.
Old 22nd February 2008, 03:43 AM   #8
EnvisionAudio is offline EnvisionAudio  United States
EnvisionAudio's Avatar
What is the "build shop"? Does somebody actually make these now?
I just repaired a newer (2000) PPI PCX amplifier with the same problem...I thought they would have had it fixed by then!
DCX2496/DEQ2496 Car Audio Conversions
www.envisionelec.net
Old 22nd February 2008, 04:12 AM   #9
Has anyone seen this type of board in a PPI amp?
OEM or not?
Old 22nd February 2008, 09:27 AM   #10
OEM or not?
Hi Perry,
I have seen these rarely, I believe firmly they are a first run card, cause they were only in very old , and early Art series amps and then never more after that.
I looked at these also before building my own, as pictured above. The device pictured in my earlier post is a replacement I and a friend redesigned to replace these older ceramic cards.
Production has not started on these yet. Offshore manufacturing had to be found as no American facility would make the 2 board run for the first 200 pieces for reasonable prices. The Proto in the pic was made on board material that cost more than a new PPI amp ever did.
Hence my statement of getting my build shop to get some of these back to me...and the issue of time...
in need of some PPI ceramic driver modulesHide this!Advertise here!
How to cut ceramic mobyd Tubes / Valves 4 3rd August 2009 12:38 AM
Little help with ceramic cap ID? peace brainerd Parts 1 4th December 2008 08:36 PM
WTB: UCD400 or 180 modules. OR, some SKA Modules Spiritzly Swap Meet 0 27th September 2008 07:08 AM
UcD modules - can the modules work without the input op-amp? beppe61 Class D 8 11th October 2006 07:35 AM
How to design Crossover circuit of the loudspeaker using accuton ceramic driver unit? kevinlin1013 Multi-Way 9 20th August 2005 09:47 PM
