Hi dears. This is my battery charger (SMPS), light, small and strong.
I like it so much, this is a 30A version, but, there are 60A and 90A too. All comments are wellcome. Thanks. CHACALPOWERS |
#2 |
VERY Nice!!!!
I like how you re-used a computer PSU case. What did you do to make this charger? What kind of transformer did you use to get the 12V+ output? Schematics? |
#3 |
Hi
Does it have current limiting? More pictures please |
#4 |
Hello SMPS builders
I'm your fan, because I learn so much with all you. Than you very much. The battery charger/power supply don't have a current limiter, only a input fuse to prevent overload or short circuit, ok? The PWM card work with SG3524, 2SC954/2SA733 buffers, IRFP264 mosfets in the output and the output transformer was build with 3 PC power supply output transformer (together) Ae = 3,6cm2 and no load the input current is only 0,04A (40mA). I will post some schematics in the future for you. Here a pic of the SMPS rear side. Thanks CHACALPOWERS |
#5 |
Hi
3 cores for 30A version? Or was that for some other? |
#6 |
Why are you not including current limiting? This yields an extremely easy to blow circuit.
I use to feel like the small child in The Emperor's New Clothes tale |
#7 |
HI luka
Yes, 3 PC power supply cores for 30A version only. Hi Eva, I'm your fan, ok? When I built the SMPS my time very short, but I want install a current limiter shutdown based in the next version. About this, what the best way to action the shutdown in the SG3524 (your suggestion)? Thanks Chacalpowers |
#8 |
Method 1:
Replace SG3524 by SG3525A and use the shutdown pin to terminate each cycle in case current rises above a certain threshold. This requires some "slope compensation" for stable operation into limiting. Method 2: Use a shunt to sense output current and one or two op-amps with suitable frequency compensation to reduce target output voltage or duty cycle in order to keep current below the limit. And so...
#9 |
Hi
Why you need 3 cores for 30A? I have 25A output with one core only |
#10 |
Hi luka
I don't know "why" but my cores are "EI33' , Ae=1,2cm2 aprox. X 3 = 3.6cm2. 74Khz switching, 2 X IRFP264. (115VAC version). Regards Chacalpowers |
| Battery Charger for 15V Li-ION Battery Pack ??? | Jan Dupont | Parts | 2 | 11th April 2009 02:18 PM |
| R/C battery and charger | jaudio | Power Supplies | 3 | 18th February 2009 07:27 PM |
| Help required for this SMPS Battery Charger | xyz9915 | Power Supplies | 13 | 14th June 2008 01:10 PM |
| Battery Charger | ThSpeakerDude88 | Everything Else | 13 | 6th September 2006 10:40 PM |
| Page generated in 0.09754 seconds (81.10% PHP - 18.90% MySQL) with 11 queries |
