help with my 500/1
help with my 500/1
Old 20th February 2008, 05:04 AM   #1
doorman3 is offline doorman3  United States
Default help with my 500/1
i'm trying to fix my jl 500/1.........i've replaced all the irfz44n's with exact replacement.........also replaced the irf540's with irf540n as the non n's are hard to find........i replaced the 44's resistors with 47 ohmers..........irlz34n was also replaced.
help
joe
Old 20th February 2008, 05:15 AM   #2
Perry Babin is offline Perry Babin  United States
What's the problem after replacing all of those parts?
Old 20th February 2008, 02:05 PM   #3
no lights, power or anything..........before i replaced the parts i had a green light...........so i replaced the blown parts which was the 44's and resistors and after further checking i found a couple of the 540's bad and replaced those as well.........the 44's were exact replacement and the 540's were replaced with the "n " version by IR..........i checked all the solder joints and they appear to be good.....
it seems that the irf540 is obsolete.......or at least the ones by "ir".
i wonder if the fairchild IRF540A would be a better replacement?
joe
Old 20th February 2008, 02:14 PM   #4
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Once I found JL500/1 amp not working because the through-hole plating malfunctioned (upper and lower tracks not connected). There are hundreds (and tiny) through holes in this amp.
Better to work with service manual or at least a schematic to fix this kind of amp.
Old 20th February 2008, 03:20 PM   #5
sdoom is offline sdoom  Germany
I dont think the 540N will cause trouble , at least the power or protect light would be turned on.
Do you have a scope ? If so try to check the gate´s signals of the irfz44. If you dont have a scope use a multimeter in frequency mode and check the output signals of the SMPS - chip. Usually a µPC494 (TL494) or similar SMPS-chip . If you find output signals around 20 KHz or higher the chip is working and tries to power the IRFZ44 . Follow the output signals from the TL494 , usually you ´ll find some small signal transistors (usually 2SA1266, or 2SA1015) connected to the outputs. The small signal transistors drive the IRFZ44 gates .
If there ´s no output on the SMPS-chip it is probably disabled, but then the protect-LED should be lit. Please check the fuse again and make sure 12V, GND and remote signals are ok.
Old 20th February 2008, 03:24 PM   #6
lumanauw's Avatar
This amp has a feature of "auto turn on" when a signal is detected (turnon without 12V to the remote terminal)
Old 20th February 2008, 03:53 PM   #7
yep but it still can be powered up with the remote turn on.
Old 20th February 2008, 06:21 PM   #8
The parts you used shouldn't cause any problems.
Is the preamp board plugged into the amp?
Are all of the pins aligned properly?
Old 20th February 2008, 07:02 PM   #9
yeah, the preamp board is plugged in............fuse? i don't see any kind of a fuse in this amp.......ok i found 2 through-hole plating malfunctions......one in the topside of the 44n's and one on the bottom of the 540n's............and the auto turn on is connected........i'm still checking....
all advice is welcome.
thanks
joe
Old 20th February 2008, 07:21 PM   #10
On the 10 pin plug near the power terminal block, post a list of the voltages on the pins. Bottom left is 1. Bottom right is 5. Top right is 6. Top left is 10.
Set the meter to DC volts. Black lead on the ground terminal of the amp.
help with my 500/1Hide this!Advertise here!
