Hifonics Boltar VIII Problem
Old 17th February 2008, 04:22 AM   #1
vypr is offline vypr  United States
Default Hifonics Boltar VIII Problem
Hi, i have recently aquired an old hifonics boltar that has a problem with drawing current only when power is applied to the remote terminal, changed out all 10 IRFZ44N mosfets in the power supply, also checked all of the 220ohm gate resistors all were within tolerance, also all output devices and drivers checked good, attached is a picture of the amplifier only the power supply fets on towards the top of the picture get warm the others are cool, amp did the same thing before i changed all the fets in the power supply i have more pics of scope readings and power supply pics of when amp is on
Old 17th February 2008, 04:25 AM   #2
here is a pic of the scope reading set at .2 volts and 50uS scope probe set at x1 taken of the leg of the first rectifier on the side of which the fets get hot
Old 17th February 2008, 04:28 AM   #3
heres a pic pf the power supply when power is applied to the remote terminal normally is at 13.8 volts
thanks for all your help
Old 17th February 2008, 05:20 AM   #4
Perry Babin is offline Perry Babin  United States
Can you post photos of the gate signal (on the gate leg of the FET) for each bank of FETs (1 photo/bank)?
If possible, also post photos of the drive signals on the base of the driver transistors.
Old 17th February 2008, 11:36 AM   #5
sdoom is offline sdoom  Germany
If the Boltar is equipped with SGSD100 and SGSD200 check them with an ohmmeter. I once worked on a VIII - Zeus and the SGSD200 had failed. The SGS are part of the power supply. If they have a short you might have trouble finding the SGSD. The company audiodesign (distributor in Germany) fixes the Series VIII amplifiers with "self made" SGSD100 / 200. transistors. They make their own darlingtons with TIP102+TIP35C (replaces SGSD100), TIP107+TIP36C (replaces SGSD200).
If there was no other source , you can get the SGSD100 here
http://bg-electronics.de
and the SGSD200 here:
www.conrad.com
You may also check the output sinal of the TL594 , as in a Pluto repair the TL594 had gone bad and didnīt provide both output signals. the TL594 is located on the small sub-board next to the transformer.
Old 17th February 2008, 10:52 PM   #6
I checked SGSD100 and SGSD200 both sets are good
perry i have photos of the gate signals of both banks starting with the top bank with respect to the first pic i posted all with scope set at 50uS and 1 VOLTS/DIV probe set on x1
Old 17th February 2008, 10:53 PM   #7
heres the gate leg of the bottom bank
Old 17th February 2008, 10:56 PM   #8
heres the photos of the drive signals starting with top one first
Old 17th February 2008, 10:57 PM   #9
now the base of the bottom driver transistor, all this was done with a 4 ohm dummy resistor in series with the 13.8 volt supply to limit current
Old 18th February 2008, 12:08 AM   #10
Pull the driver transistor (2SD1292?) and check it. If it's OK, the output transistor of the TL594 may have failed. Check the drive signal on pins 9 and 10 of the 594 with the driver transistor out of the circuit. It should look more like the drive signal you have on the bottom bank of FETs.
If you pull both driver transistors, the voltage drop through your 4 ohm resistor should be much less and should allow the drive signal to swing to ~12v. The low voltage (caused by the 4 ohm resistor) could be causing the driver IC to go into shutdown. If you have two 4 ohm resistors, connect them in parallel to allow more voltage at the amp.
Hifonics Boltar VIII ProblemHide this!Advertise here!
hifonics VIII zues and gemeni anthonyc213 Parts 1 9th April 2009 02:42 AM
hifonics viii bridged mono? rca q... marko Car Audio 4 27th February 2009 06:10 PM
hifonics viii remote turn on issues.... marko Car Audio 2 26th February 2009 05:50 PM
boltar generation x old school badcompany Car Audio 2 27th July 2008 01:13 AM
Hifonics Problem swordfish689 Car Audio 5 2nd April 2007 04:49 PM
Copyright ©1999-2017 diyAudio
