Go Back   Home > Forums > General Interest > Car Audio
Old 22nd January 2008, 09:44 AM   #1
iUSERTLO72p's Avatar
Default Bypassing switcher
Hi, I want to run my car amp off the mains, not via 12volts but, by bypassing the switchmode supply and using a Linear supply.
I have found what I believe to be the smoothers and rectifiers, and at the smoothers measured +/- 9v, (Fed from a battery charger). Funny, my battery charger, no load, measured 11 volts ?? Somewhat 3 volts low. So would I place 22volts at the smoothers, and should I isolate the switcher or leave it??
Please help.
iUSERTLO72p
Old 22nd January 2008, 09:45 AM   #2
Default Another PIC
Thankyou
Old 22nd January 2008, 09:57 AM   #3
You'll need a split supply (both positive and negative voltage). To know what the secondary voltage should be, you need to get the power supply in the amp working properly. With 11 volts in, you should have more than ±9v.
When you find the right split supply for the amp, you can remove the rectifiers and connect the split supply to the center legs of the rectifiers (assuming that the output of the rectifiers is on the center leg).
There may be muting issues that you'll have to deal with also.
Old 22nd January 2008, 10:07 AM   #4
Default Doh, damn keyboard
Sorry, should have read 19 volts
9v
Thanks, iUSERTLO72p
Old 22nd January 2008, 12:12 PM   #5
Default While I got it apart
Can any tweaking be applied here?
Thankyou
iUSERTLO72p
My DIY Pre amp switcher pops! MuthaFunk Parts 5 6th May 2009 02:07 PM
Good source switcher MotoMan_Yz400 Pass Labs 4 22nd February 2009 02:25 AM
WTB: abx switcher garlandstephens Swap Meet 8 2nd December 2006 09:41 PM
First Gainclone..with a 'switcher' and 'XO' mpmarino Chip Amps 17 7th October 2004 01:10 AM
Anyone use an offline switcher PS for GC? speaker Chip Amps 4 26th March 2004 01:02 PM
Page generated in 0.07481 seconds (76.12% PHP - 23.88% MySQL) with 11 queries
