Go Back   Home > Forums > General Interest > Car Audio
Old 18th January 2008, 05:41 AM   #11
jol50 is offline jol50  United States
The TO-220 get warm and are on a sink. I will try to check it tomorrow, was using it to test today. Used to using the HU to turn the amp on/off and this is a pain.
Old 18th January 2008, 06:25 AM   #12
In other aiwa CD players (Z117, Z107) they use TO-220 transistors (Q601?) to control the switched power that feeds the rest of the head unit. The 2.2 ohm resistor taps off of that switched power bus. If the rest of the head unit is switching on and off properly, the switching transistor probably survived.
Old 18th January 2008, 03:32 PM   #13
Everything works fine but the remote. It looks to go right to the TO-220s and has B+ to that resistor, and continuity there to the remote pin on plug. Well actually some mv to pin.
12v stops at top of R803 in photo. Lets see if this works, I have a red crayon here...
Old 18th January 2008, 04:43 PM   #14
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
Hi
If it stops there, and if you try to measure resistor directly and it doesn't show 2.2 or lower, you will have to replace it..
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Remote volume control for existing remote? theAnonymous1 Parts 7 6th August 2007 08:22 AM
Remote volume - existing remote Stuey Chip Amps 16 25th August 2006 11:44 PM
Remote Zap Standby circuit robomatique Class D 0 23rd March 2005 05:02 PM
Remote trigger circuit for amp Gaber Solid State 7 1st February 2002 05:25 PM
Page generated in 0.07732 seconds (72.68% PHP - 27.32% MySQL) with 10 queries
