Go Back   Home > Forums > General Interest > Car Audio
Old 15th January 2008, 04:32 AM   #1
MikeHunt79's Avatar
Default Whats the max voltage my cars electrical system will generate?
I've just managed to pull apart another broken car amp, and I've pretty much struck gold as I can use the SPMS from it.
Now, I've tested it at different voltages...
12v in = 26v out
13v in = 28v out
14v in = 30v out
15v in = 32v out
16v in = 34v out
I've rounded the values a little but you get the idea...
Now the amp module I want to power (41Hz AMP9) says the max voltage is 26v... So I'm guessing the 30v will be too high for it...
Now, I may try a diode or two on the input to bring the voltage down a little, or even lose a turn on the secondary windings, but I need to know if my car's electrical system is ever going to go over 14v at all?
I've tried searching, and found mixed results, and no definite answers.
I'm tempted to treat 15v as the absolute max....
Old 15th January 2008, 04:56 AM   #2
sandyK is offline sandyK  Australia
Default max voltage car electrical system
MikeHunt79
Times change, but alternators USED to be adjusted to give 13.8 to 14.2V. Significantly hgher voltage is likely to shorten battery and headlights life.
SandyK
Old 15th January 2008, 05:53 AM   #3
What make/model amp is it?
You may be able to regulate the power supply to limit it to 26v.
Old 15th January 2008, 01:04 PM   #4
MikeHunt79's Avatar
Default Re: max voltage car electrical system
Originally posted by sandyK
MikeHunt79
Times change, but alternators USED to be adjusted to give 13.8 to 14.2V. Significantly hgher voltage is likely to shorten battery and headlights life. My car is 15 years old anyway, so I guess it confirms to the rules.
SandyK
Ahh, ok... I'll treat 15v as the limit to be on the safe side.
God knows what make it is...
It's big and purple, and says on the front:
MOSFET | AMP-600
AMPLIFIER | 150W X 4CH
| 600W MAX
It looks pretty cheap and nasty, but the rails are pretty ripple free, and the toroid has rather thick cables, meaning it should give a good amount of current...
Anyway, I simply took 1 winding of both of the secondary windings, and now I got 28V at 16v input, and 26v at 15v. This is perfect!
EDIT: What's the best way of removing enamel from magnet wire?
Old 15th January 2008, 02:27 PM   #5
Bobken is offline Bobken  United Kingdom
I have measured a lot of vehicle systems' voltages over the years, and 14.6VDC is the highest I can recall seeing on any non-commercial vehicles. This is when charging was taking place, of course, and with a low loading, but most commercial vehicles favour nominal 24V.
Incidentally, many people don't seem to appreciate that a fully-charged nominal 12V car battery should give around 12.6volts minimum, without any concurrent charging taking place (i.e. without the engine running).
Regarding the removing of enamel issue, it depends on the specific application, but I have used 'scraping' with almost anything from a sharp pen-knife, Stanley knife, scalpel etc., or 'abrading' with fine sandpaper, wet & dry, and emery cloth etc. Some enamel is made to simply 'burn off' when heated sufficiently for soldering, without the need for any removal process prior to soldering, so it will depend on what you need to remove the enamel for.
A long while ago, the enamels used could often be removed with certain solvents, but nowadays I have not had any success with anything used in this manner as the varnishes are usually much better made and often epoxy, polyurethane or similar plastics-based materials.
Bob
Old 15th January 2008, 03:20 PM   #6
Speakerholic
Cal Weldon's Avatar
Default Re: Re: max voltage car electrical system
Sandpaper?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 15th January 2008, 04:33 PM   #7
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
Default Re: Re: Re: max voltage car electrical system
Originally posted by Cal Weldon
Sandpaper?
I use something called lavacol, it removers paint and stuff like that from wood or metal, but wire that I've bought today...you only need to heat it over ~150-200C and remove/take off insulation by hand
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 15th January 2008, 04:56 PM   #8
MikeHunt79's Avatar
I used the file on my leatherman in the end... It worked as the wire took the solder, even if it needed lots of it.
That being said, I've truly butchered it!
Before starting to mod it, I knew the amp didn't work, and I didn't know why... Now I think I do....
When measuring the voltage, it was always with no load....
Even after I changed the number of turns on the toroid, the voltage seemed fine.
I then hacksawed off the amp part of the board. The voltage seemed spot on.
I then tested it with a tiny load... nothing! The voltage rail just drops to zero! If only I tested this before spending hours desoldering and hacksawing....
Anyway, I now have this rather fetching doorstop.
Old 15th January 2008, 06:31 PM   #9
When you connected it to a load, did the pulses on the center legs of the power supply FETs go to straight DC (no pulses) equal to the B+ voltage?
Old 15th January 2008, 08:07 PM   #10
MikeHunt79's Avatar
They stay exactly the same on both sets power supply FETs, squarewave at 14v (B+ voltage) at 27KHz, weather load is connected or now.
I remeasured the output voltage again tho, it doesn't drop to 0v anymore, it drops to 6v when I connected a small load... I'm not sure whats causing this, but it probably explains why the amp didn't output anything thru the speakers...
The load I connected was a 24v fan rated at 750mA.
I couldn't really find anything with a lower load...
Whats your ultimate DIY system? fatmarley Everything Else 0 7th December 2007 09:19 AM
Constant Voltage System redback Everything Else 8 13th February 2006 03:40 AM
Whats your opinion on this little system ? istari knight Digital Source 0 3rd November 2005 10:30 PM
1991 Toyota MR2 Turbo Custom Amp/Subwoofer - Questions on Electrical System Upgrades newsystem Car Audio 4 4th November 2004 01:34 PM
Whats the voltage rating on this wire? lgreen Parts 3 20th October 2004 09:08 PM
Page generated in 0.11538 seconds (89.26% PHP - 10.74% MySQL) with 11 queries
