Whats the max voltage my cars electrical system will generate?
Old 15th January 2008, 08:31 PM   #11
Perry Babin is offline Perry Babin  United States
The secondary may be completely isolated from the primary. When you measure the voltage on the secondary, you need to use the secondary center tap as the reference (black meter lead in sec center tap).
Using the secondary center tap as the reference, do the pulses on the outer legs of the rectifiers maintain the same amplitude when you connect the fan?
Old 15th January 2008, 08:59 PM   #12
MikeHunt79 is offline MikeHunt79  United Kingdom
MikeHunt79's Avatar
Damn, I totally forgot about the grounds being isolated... I was using the ground on the input all along.
The blob of solder in the middle of the output caps is actually the secondary ground. So I simply wired the fan up to secondary ground instead of the primary ground, and it starting whizzing away at 26v.
This was definitely a eureka moment for me, thank you! I can now get around to squeezing the amp9 into the amp case.
Whats the max voltage my cars electrical system will generate?Hide this!Advertise here!
Whats your ultimate DIY system? fatmarley Everything Else 0 7th December 2007 09:19 AM
Constant Voltage System redback Everything Else 8 13th February 2006 03:40 AM
Whats your opinion on this little system ? istari knight Digital Source 0 3rd November 2005 10:30 PM
1991 Toyota MR2 Turbo Custom Amp/Subwoofer - Questions on Electrical System Upgrades newsystem Car Audio 4 4th November 2004 01:34 PM
Whats the voltage rating on this wire? lgreen Parts 3 20th October 2004 09:08 PM
Copyright ©1999-2017 diyAudio
