Go Back   Home > Forums > General Interest > Car Audio
Old 2nd January 2008, 04:15 PM   #11
Cxrazy is offline Cxrazy  United States
Who what huh?
Old 2nd January 2008, 05:36 PM   #12
jol50 is offline jol50  United States
Check the gate resistors. Here is another thread about this part: http://www.diyaudio.com/forums/showthread/t-70048.html
The left pin should go to a resistor, likely the tan colored one next to each chip. When you take the mosfets out test ohms on those resistors (they will be hooked to nothing) and see if they are the same, some people recommend you put them in new as well since they don't cost hardly anything and should ensure the mosfets all share the load equally, or make output equally if outputs. If a bad mosfet shorts to the gate it can send full current up that resistor to the driver in a power supply or it looks like in yours that is the output, so like was said it can damage the differential amplifier/etc. Or it all may be fine hard to say but checking the gate resistors is easy and a good idea.
Old 3rd January 2008, 03:24 AM   #13
thats a good plan.
Will do
mtx amp problem [[help!!]] fuzzypinkhat45 Car Audio 3 8th July 2008 05:34 AM
FRD/ZMA Problem Twisted85 Multi-Way 5 4th December 2006 01:19 PM
p3a problem MaXiZ Solid State 17 16th July 2005 07:14 AM
GC amp problem Jamh Chip Amps 30 6th April 2004 02:50 PM
Page generated in 0.07105 seconds (69.94% PHP - 30.06% MySQL) with 10 queries
