#11 |
Ok people, I used a 40 fuse, but the light on my amp is dim. Could that be because I need a larger fuse?
#12 |
There isn't enough power coming from the trumpstick to the canutin valve, check there first! Happy New Years! Polo..
Safe_Cracker :O)~ |
#13 |
No the 40 amp fuse is not the reason the light on your amp is dim. Does the amp work?
If it ain't broke Don't fix it |
#14 |
AGU fuses suck balls....get a real wafer style fuse...ANL
#15 |
Agu fuses are great, it is the fuse holders manufactured by the car audio companies that suck. The fuses were not designed to be in a sealed enclosure. If the fuse holder allows heat to escape from the fuse, they are great.
#16 |
they are OK for small systems pulling less than 60 amps.
if the manufactures came up with a hold that actually had a real clamp for them than they would be mediocre...the "clamps" on the fuse holders are very weak and provide weak contact points |
#17 |
My 5ga kit came with a maxi fuse 100a. It seems ok so far. I used to use atc 30a on battery, or two. I used the covered outdoor holders because they corroded otherwise. I still had to pack the holder with dielectric grease and then they would hold up pretty well. That reminds me I should put some in this 100a. That stuff works great on lots of things like trailer plugs and ignition systems.
| Fuse housing melting but fuse not blowing, ppi amp | rawadia | Car Audio | 21 | 2nd August 2008 10:39 AM |
| SMD Fuse | stef1777 | Parts | 2 | 26th April 2007 12:03 AM |
| Why main fuse and not rail fuse? | digital desire | Solid State | 10 | 3rd December 2006 08:07 PM |
| amp rating for fuse and fuse holder? | riotubes | Parts | 5 | 27th August 2006 03:10 AM |
| Page generated in 0.08703 seconds (74.45% PHP - 25.55% MySQL) with 10 queries |
