Go Back   Home > Forums > General Interest > Car Audio
Old 22nd December 2007, 02:41 AM   #1
Default MTX Jackhammer vs MTS 4500
Hello. I can buy a MTX Jackhammer subwoofer for $5000 us. For the same price I can buy 50 MTX 12 inch Thunder 4500 single voice coil woofers. You might have seen the MTV series "Pimp My Ride". It is used in a full size van. See it? Assuming you are using the same amplifier, lets say a Rockford Fosgate T15kw (15000 watts RMS) at $20,000. Which system will produce more sound? SPL. Bass?
Old 22nd December 2007, 03:01 AM   #2
ppia600 is offline ppia600  United States
I think I would go with the 4500's if space wasn't a concern. That is definately enough power to push them all adequately. Heavy huge subs are for people who have to have the biggest shiniest toys. But... they do have the new mtx jackhammer 45 series which replaces the 4500's and they handle a little more power and are built better. (sewn in lead wires and rubber surround)
I'm waiting on the shallow subs from Mtx to come out, anyone know when? I emailed them and they just told me "I can't give any details, but very soon" I can't wait!
Don't worry... you can always turn the gain down!
Old 22nd December 2007, 03:55 AM   #3
Clipped is offline Clipped  Thailand
Send a message via MSN to Clipped
if your spending that much id go with a DD Z series sub...its the shizzle
Old 22nd December 2007, 12:25 PM   #4
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
and one 18"er will go louder than one jackhammer.
as for the question of 1x 22" or 50X 12"....
just remember, loud = moving lots of air. so you'll go louder with more total cone area....if you have the space.
Old 22nd December 2007, 01:11 PM   #5
Default changing my question
25 cheap made in china style woofers no matter what the surface area will not outperform one large 22 inch quality driver. Right? ER in San Diego has these drivers for about $6 each. They are also available in LA area from Davy Levy Co. I am changing the original question.
Old 22nd December 2007, 02:17 PM   #6
Default Re: changing my question
Not likely. Like djQUAN and I am saying, having that many woofers is going to outpound that one jackhammer, especially when you have more power than they require. The cheaper woofers may be made in china but they are to mtx specs. And like I told you, there is also the new JH (jackhammer) series of the 45's that are even better made than the 4500 subs. Plus, your original question was about 50 woofers, not 25.
Old 22nd December 2007, 05:20 PM   #7
jol50 is offline jol50  United States
I thought I read one DD did 180db? What was it a 15 or 18"? And had a ton of power on it. Also read their subs don't even have that much xmax.
Old 22nd December 2007, 06:37 PM   #8
Alan Dante posted 180.5dBat 2x event dB Drag just this week!
Loudest car in the planet using just a single DD9918Z and 4x Stetsom 7kd.
Old 23rd December 2007, 01:06 AM   #9
The MTX Jackhammer is a joke.
two quality 15's in a custom enclosure for them will outperform the Jackhammer.
They will cost less...be more efficient...and not look retarded
Lets see what you need for a Jackhammer.
6000 watts rms
two 250 amp alternators.
A hug SUV to fit the 20 cu ft enclosure.
Suspension upgrades.
Possibly tire upgrades to handle all the weight
The enclosure would weight hundreds of pounds
1000+ dollars in batteries.
hundreds of feet of 0 gauge wiring.
A forklift.
The MTX Jackhammer is far from a realistic driver.
Old 23rd December 2007, 01:50 AM   #10
that 180 was a test tone, an extreme vehicle isnt really designed to play music... you cant even sit in the cars, unless youre a dwarf, much less drive it
the jackhammer is unproven so far.
the 25 subs will outpound a jackhammer, there will be more voice coils to dissipate the heat, the cost for wiring is also going to be much much much higher.
you should base your design on the airspace you have as well as the vehicle, a 18" sub wont always be louder than a 12" sub in an automotive environment, you have to give room for the wave to develop...for 25 subs, the box is going to have to be set back futher than usual do to the smaller box space available....
Amplifier for MTX Jackhammer? icecoolwas Car Audio 21 10th January 2009 05:08 PM
Electrohome ECP-4500+ HD projector - $250 OBO! Spasticteapot Swap Meet 0 19th December 2008 10:21 PM
Schematic for Marantz SR-4500 , anyone? mayky Solid State 0 26th May 2006 08:19 AM
Can I use an old Sansui QR-4500 amp? tylercv Everything Else 1 17th July 2003 10:31 AM
Page generated in 0.16636 seconds (55.79% PHP - 44.21% MySQL) with 11 queries
