#11 |
The board is blue, the camera just makes it look green. It's a MPSA56 (PNP) with the collector tied to ground, it's connected to a GE D40D8. There is one of each on each side. I'll circle them in the pic that I posted.
http://www.kernclassifieds.com/forum...o/DSC07579.JPG |
#12 |
In most of their other amplifiers, they use Pulse Amplitude Modulation instead of Pulse Width Modulation. Since the regulator seems to be different (absent?), I was trying to determine if they're using PWM in this amp.
In the other amps, they use something similar to the attached image. If the collector of the NPN driver (D40D8) is connected to B+, it's likely that it's either unregulated or uses pulse width modulation. After you replaced the defective parts, did the rail voltage increase?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
| Old School Orion 2150 gx.I must repair this amp | spooney | Car Audio | 99 | 21st August 2010 02:53 PM |
| Orion 280GX amp repair | thegmann | Car Audio | 11 | 11th April 2008 05:44 PM |
| couple old school orion questions | Clipped | Car Audio | 3 | 5th August 2006 10:09 PM |
| Orion Construction Questions | ¿GotJazz? | Multi-Way | 3 | 6th October 2004 04:44 PM |
| Orion questions | dayneger | Multi-Way | 8 | 4th March 2004 09:28 PM |
| Page generated in 0.08277 seconds (66.46% PHP - 33.54% MySQL) with 11 queries |
