Go Back   Home > Forums > General Interest > Car Audio
Old 12th December 2007, 06:52 PM   #1
marko is offline marko  United Kingdom
Default red hot transformer?
what would cause this? a short i guess? the amp actually works for a bit untill my power supply trips out and the cables get warm too in the process!!
Old 12th December 2007, 07:27 PM   #2
jol50 is offline jol50  United States
Transformer shorted?
Old 12th December 2007, 07:29 PM   #3
i'll have a poke around, could be this as some of the anodising on the transfomer wiring is slightly scorched....
Old 12th December 2007, 08:13 PM   #4
shagone is offline shagone  United States
try twisting with something while you play music and see if it comes and goes. look for a powdery substance between the shorted windings. they often short where the leads bend down to go into the board. if you can find the short you may be able to isolate it with kapton tape or new epoxy.
Old 13th December 2007, 11:07 PM   #5
Might your amp be suffering from simultaneous conduction in the transistors (FETs on my amps) that drive the transformer's primary? If so, this could be caused by a damaged gate drive circuit or by the use of replacement FETs having larger gate to source capacitances than the drive circuit was designed for.
Old 15th December 2007, 03:25 PM   #6
this is the amp, it's a bbg ryval by phoenix gold, it play fine for a few minutes then the transformer gets too hot to touch, i've ohmed all the devices out and they seam fine....
also the trasformer starts to very slightly smoke!!
Old 15th December 2007, 10:02 PM   #7
Pull the rectifiers out of the circuit. If the current draw remains high, you know the problem is in the supply. If the current draw goes down to ~1 amp, the problem is in the audio section.
After pulling the rectifiers, you need to put the board back in the sink and clamp the transistors down tightly. High current draw will destroy parts in seconds if they're not clamped to the sink.
Old 22nd June 2008, 05:21 PM   #8
hi all, i just got round to looking at this again as it's sunday and i'm board!
i pulled the rectifiers out and powered it up, within seconds the transformer was too hot to touch!! i didn't do a current draw check but i'm certain it would be high still...
do i have a shrorted transformer? i guess the only way to tell is to pull the transformer and do continuity tests..
Using mains transformer as output transformer Elias Tubes / Valves 175 3rd November 2009 08:36 PM
Modulation transformer for a driver transformer? ironradio Tubes / Valves 6 28th December 2008 05:05 PM
filament transformer vs plate transformer contaxchen Tubes / Valves 10 14th January 2005 10:43 AM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.09945 seconds (78.54% PHP - 21.46% MySQL) with 11 queries
