i was wondering what the cons are of a sound system with 2 boxes would be. i have 3 15" subs and the easiest way to fit them into my truck is to have 2 in a sealed enclosure and one in a ported box. would this cause any major problems sound wise or should i just do 2 sealed enclosures?
thanks ahead of time, p.s. this is my first post, i'm fresh to the forum |
#2 |
welcome to the forum.
can you put two in a sealed box and the third in another smaller sealed box? You should try to stay away from mixing and matching different boxes or speakers. It's not good practice to do so. You'll get different sound from both boxes and I'm willing to bet it won't integrate well with the rest of your system. Why not just use two of them? two 15's will still put out quite a bit of bass. |
#3 | |
i second that idea. it would be better to just use 2 15" subs in the correct size enclosure with the right amount of power. plus you might have room left to actually put stuff in your trunk when you need to. |
#4 |
A well designed single 15" sub enclosure will out do three poorly built ones! A sub will need room to breath, too much in a trunk will cause cancellation problems. Here was my approach to a single system and I will be redoing it again with my finalized box ( last picture.). Polo..
Safe_Cracker :O)~ |
#5 |
I'd say put them all in there own sealed box, but thats just my personal preference.
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1 |
#6 | |
If you must have all three 15" subs, I would build 3 separate sealed boxes, put them into the trunk, then bolt them all together. As stated above, and depending on the size of your trunk, you may have cancellation problems. In other words.. "too much box and not enough trunk." |
#7 |
its a decently sized SUV and i'm really hung up on 3 subs so i guess i'll go sealed for quality and smaller size. my next question would be 3 single enclosures and not a triple?
#8 |
like i said, i like separate enclosures for my subs.
3 15's is allot for a car. what are you gonna use for mids and highs? i bet eventually you'll decide 3 15's is more then needed or need more space in your vehicle and take out a 15 or 2, so may as well build them separately so you can pull them out as desired too.
#9 |
3 subs are great; I have personally always liked the odd number setups. Remember that 3-4 subs (or more), during everyday listening will be working less than the same volume where 1 or 2 subs is used.
This is what I recommend: Do not mix ported and sealed encloses in the same car. You will loose SPL because the wave forms will different between sealed and ported, the different wave forms will not align and cause cancellation. Some people may think I am crazy and it wont have much of an affect but I have spent a great deal of time and effort experimenting with wave alignment for SQ/SPL and I have NEVER found a benefit for the very susceptible low Hz in doing anything that can alter a wave from another sub in a controlled environment (car for instance). Do not mix sub sizes…..for the same above reason. Do not have different sized boxes…..again for the same reason Have all of your subs in the same plane….unless you have frequency alignment processors and STILL only want a small frequency range. |
#10 |
cool, thanks
it's a done deal. i'll do 3 seperate boxes all the same specs and on the same plane i'm hoping. and as for the midsand highs i have 2 sets of jbl 6.5 gti series components and a set of 6.5 full ranges for my center speaker. all jbl power series amps (total of 4) i especially like sub amp because it wasmade by crown for jbl anyways, thanks for the advice |
| What's your system looking like right now? | jduffy | Chip Amps | 1 | 5th May 2008 08:38 AM |
| Help with PSU for Tri-Amp System | snax | Power Supplies | 9 | 16th July 2007 08:17 PM |
| Dj System | GOWA | Multi-Way | 5 | 6th July 2007 03:57 PM |
| Keep RFI out of your system? | I_Forgot | Everything Else | 3 | 5th July 2007 02:34 AM |
| PIC Of My system in the car | Dj BASS AMP | Car Audio | 10 | 10th January 2004 10:38 AM |
| Page generated in 0.11883 seconds (80.85% PHP - 19.15% MySQL) with 10 queries |
