What about big IC amps, STK****?
Old 2nd January 2008, 12:09 AM   #21
jol50 is offline jol50  United States
I'll try to post a pic if I get time, there is not much inside the output section of this Blaupunkt. I don't think ampguts has one on there, pretty fierce little amp though if you can use what it gives out. If I knew enough about it I would try to change the sound of it, give it more bass....but for IB 10s it is perfect.
Old 1st April 2009, 01:25 AM   #22
Originally posted by tsmith1315
A BPA260 and some old efficient IB 10's.
If yours is blowing the fuse at turn-on, it's most likely the IC. I only replaced a few, but all were verifiably shorted without even removing them from the board. Often the damage is visible.
LOL, digging DEEP here but I finally (after removing some dust) finished fixing the poor old BPA260! Perry is still laughing at me. It was all messed up with low rail voltage and just crazy looking PS IC on the scope....yep, plugged the RCA in and it worked fine (lots of colorful wording could describe it) The amp is fully floating but for a wire to the PS IC. I get 4mv DC offset on the new STK and 57 on the old one, and single digits mv on the second BPA260 I have....so I'm ordering another STK for the other channel. When I get my power test bench fully setup I'll wring it out a little and see what it does compared to some other amps. The STK was fully shorted rail to output, not sure how it did not blow the subs in the car just blew the fuse, 20A I think. It has ~28v on rails with 13.5v in, there was no visible damage on this STK.
I'd say this might have had a little less power than a coustic amp300 I also ran in there at the time, but something was different because this was much more stable on the IB subs. I want to say dampening but likely was something else. Maybe less headroom, I'm just not sure. It did distort at close to the same time, but the coustic would knock the subs out of control when it did and this did not.
I beat this amp senseless for at least three (great) years on four 10" 4 ohm subs, daily in the summer. Nice hot trunk, at the beach, poor thing lol and I got it used It will have to sit here just a little while longer with no cover. I have photos will try to post one when I have a minute.
Old 1st April 2009, 03:30 AM   #23
tsmith1315 is offline tsmith1315  United States
tsmith1315's Avatar
So, from where did you source that STK084?
Psst, Perry... don't laugh, jol's having fun!
Same here. It had to withstand my barely 18 year-old self, first year at college, parties, beach trips, road trips. If the car was running, the stereo was cranked. Neither the 260 or 430 ever shut down or blew a fuse.
Tim
Old 1st April 2009, 04:13 AM   #24
Heck I didn't know there were any amps out there that would not run without the shields grounded I blew it up long ago, must have been 1990 give or take. One day I got mad because it was still broken and my amp guy moved, eventually I decided to fix it myself...and here I am, a little smarter.
Oh yes, the good days. That amp was in a 6.6 T/A for a while and it was never shut off, serious hours on that one. I did have a fan on it much of the time, but those trunks got hot. Had two of these running the system for a while, also with a sanyo and coustics, swapped amps all the time it seemed. Even ran a PB300 I think it was, it worked but not as much power.
STK084G from Littlediode, they also list them on epay 170191788696 I put in an offer they have taken them before. Just nobody buy them all before I get one please....though not sure who would need many.
Here is a gut pic of the little critter:
Old 1st April 2009, 06:44 AM   #25
tsmith1315's Avatar
The BPA430's manual suggested installing the amp with GROUNDED SPEAKER RETURNS!!! I don't think the 260's did, I always assumed it was the same amp bridged. Didn't see many 260's, either.
Curious how they added a "shield" between the PS and amp. IIRC, they are two separate PC boards that looked like they were produced together then snapped apart. I dunno, maybe I'm mixing up memories.
And to digress... At that time Blaupunkt included schematics along with the manual. And the earlier versions of that amp had white lettering instead of the beige. They changed it to match the look of their new line of cassette decks.
I still remember opening mine up and admiring the new lettering, the first I'd seen like that. Somehow it looked nicer than the plain black and white.
Tim
Old 1st April 2009, 07:57 PM   #26
There are only three wires across the bottom connecting the two boards, common and the rails. The ones on the top are mostly power stuff for the DIN power/remote and the thermal, one wire does something not looked yet...something to the PS IC and with the rails offset 12v floating it messed it all up. It had ~10+/-v on rails instead of 28. The center divider might also be mostly to hold the amp together; the two ends are otherwise the only thing holding the two sinks and the top/bottom covers screw to the divider also.
These STK are only one channel. I thought you can't bridge them? Now I think I'm getting an ADS with the 082 in it you can't get anymore, wonder if an 84 would fit...if they are bad. I'll have to keep an eye on my junk amps, if one has a good PS I will set it aside and maybe some day see if I can build one of these....tweak the sound a little more. I should build a schematic of this or search for one, see if I can change it a little. My guess is the STK has a subsonic in it, or this board does. Guess I could run tones and see if it cuts the bottom off.
I never wanted the smaller one as I knew I would never use it. It did want one of the wand EQs but was told they were not so good.
Old 1st April 2009, 08:54 PM   #27
1moreamp is offline 1moreamp  United States
You should monitor Ebay for 084's I just saw 4 sell for $9.99 3 weeks ago from a service person that was selling off his inventory. I almost bought them myself. Plus if you search there is another seller retailing them also, and Ampslab has some also as I recall...good luck...
Old 1st April 2009, 10:44 PM   #28
tsmith1315's Avatar
Duh, how silly of me.
That was my incorrect assumption (way back when): since the 430 was common ground 4-ch out, the 260 was a bridged 430.
The wand (stalk, gooseneck) EQ's were noisy and ended up in the way. The older early 80's version was cooler because it had little VU meters instead of LED's. Both were about average for a moderately priced 80's EQ.
jol and 1moreamp, thanks for the ebay tip. Looks like the Sanyo 461's are out there and prices are reasonable.
Tim
Old 2nd April 2009, 12:26 AM   #29
I was looking at this class D but you can't find the datasheet in english. It looks significantly more complex yet possibly workable for the less experienced like me. Four 086Gs might make a nice car amp too but why not go with a newer and more available one if I were to build an amp. Still wonder about the distortion ratings, then again I'd only need 100rms in a car if that.
Yeah , back then all I knew was these amps sucked because they didn't have those shiny round things in them (TO3) like LP and coustic/etc had However I found out it ran my IB subs so well, that was good enough for me. The sanyo amps had them too, guess that makes sense now.
I'll dig into these more, found some other threads on them to read also.
Old 2nd April 2009, 02:44 AM   #30
Glad to be of help. Hope the supplier leads work out for you....
What about big IC amps, STK****?Hide this!Advertise here!
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 20 12th May 2015 12:23 PM
For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! opc Swap Meet 23 2nd November 2009 05:04 PM
Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest mbcouple Swap Meet 2 27th October 2008 10:27 PM
Why do some Bogan amps sound so good as guitar amps? amperex Instruments and Amps 7 22nd June 2006 11:46 AM
Has anyone compared GC amps(LM3875/3886/4780) with other DIY SS amps(Leach,ESP) ? percy Chip Amps 31 13th January 2006 01:33 AM
Copyright ©1999-2017 diyAudio
