Go Back   Home > Forums > General Interest > Car Audio
Old 17th December 2007, 06:07 PM   #21
jol50 is offline jol50  United States
It would be nice if they had reverse switches on one, lol. That is ampguts picture but I can tear into mine later and tell you. They are kind of a pita to take apart as you can see. I should find some of those RCA terminals and drill the case, mount them in. Keep using a DIN to RCA dongle....in fact if I built a box for this I could power it off the DIN cables and not use RCA, unlikely I would use it on another set of amps anyway.
Old 17th December 2007, 07:02 PM   #22
tsmith1315's Avatar
Well, it *could* actually be as simple as swapping a couple of connections and rearranging resistor values...
Old 18th December 2007, 11:13 AM   #23
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
here's what I did this afternoon....
I added a dual op amp on top of an existing dual op amp so that I could add an inverter and buffer before the input stage so the amp could be made tri-mode capable.
Old 19th December 2007, 07:49 PM   #24
That is some handy work! I would try to convert these to modern bridgeable amps but I don't yet know if it is possible, or better to make a box/converter.
Old 20th December 2007, 05:32 AM   #25
tsmith1315's Avatar
jol:
When you have time, shine a flashlight through the vents on the side of the 3518 and see if you can read a part # on one of those IC's. They may allow changes similar to djQUAN's.
Tim
Old 20th December 2007, 05:48 AM   #26
If the circuit is like the one in the 3550, you should be able to make only a few changes to get the channel inverted.
Old 20th December 2007, 03:18 PM   #27
It looks like upc1225H, not 100% on the 5 but 95% on it. Had to take it apart and still has stuff on it that will not come off.
http://www.datasheetcatalog.com/data...UPC1225H.shtml
Old 20th December 2007, 07:35 PM   #28
Pin 4 and 5 are normal and inverted, but it can't be that easy....
Old 20th December 2007, 08:50 PM   #29
It wouldn't be quite as easy as simply moving the input signal to the other pin. If the circuit was similar to the 3550, you'd have to remove the signal from the + input and ground the +input. Then you'd have to change the value of at least one resistor and one capacitor before connecting the signal line to the - input.
Is the F5 designed to be bridgable? speakrsrfun Pass Labs 1 24th April 2009 08:57 AM
Carver PM1.5A - Bridgable? AltheaToldMe Solid State 26 26th November 2008 03:01 AM
STK4231II bridgable? Enlight Chip Amps 0 11th July 2007 10:14 PM
Determining T/S Specs of a sub nuttinbutSQ Subwoofers 1 29th February 2004 05:00 PM
Help, Determining T/S VAS gjeff80 Multi-Way 10 1st February 2004 08:17 PM
Page generated in 0.08872 seconds (78.92% PHP - 21.08% MySQL) with 11 queries
