#51 |
Yes the volume is 10K audio, but I just can't find one anyplace. I found the right one but no taper. I think I can find something to work for the rest of the 50K pots, but not stereo volume with the switch. Was wondering if I can build my own, take them apart. Otherwise I will have to get a cable made for the volume and the rest I can do with whatever pot I find that fits. That is only way tips will do it is to send to them. Have another regular pa2 with a bad volume pot too, one channel is gone.
#52 |
If you have a linear pot that is precisely what you need except for the taper, you can make it work more like a log taper by adding a resistor.
http://sound.westhost.com/project01.htm If you can find a pot with the log taper elements and the same style frame/housing, it's very likely you can swap the resistive elements.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#53 |
So then maybe I should try some micro-surgery?
Yes I think I emailed you that place with the one for some diy amp. This broken one I bet is just the wiper, it is good end to end just wiper is gone and I would guess the wipers are same for same model. Also found one with a switch but not stereo, I think they are just modular but yet to investigate that completely with other stuff that showed up here to play with. Actually now I can take that one off the pa2 board and look at it.I could use the resistor on mine then (great!), I don't care if it is perfect just close. Heard about that someplace but did not realize it was so simple. The other one he may not like that, will try to peel that one apart soon and see what I have once I get these amps out of my way. Mouser has singles on p575 I think, even a switch on one. |
#54 |
The pot is on amb.org/shop. Go to bottom 7th line up, look at the number then click and it will link to data sheet and find it on there to see specs.
#55 |
I could not locate the one I took apart but i did find a pot off the other one alps pot Ga503B
linear power/ oz audio/ clarion |
| XY PAD/weird potentiometers to use instead of Fader Pots? | VvvvvV | Parts | 2 | 8th August 2007 10:27 AM |
| volume pots for tube amp | Miller-8 | Parts | 5 | 16th February 2007 04:29 PM |
| Volume pots: Why are low values better? | Christer | Parts | 11 | 9th January 2006 10:41 PM |
| 1 remote for 2 mono volume pots? | snowbubba | Everything Else | 0 | 21st April 2005 09:38 PM |
| Best Volume Pots? | A3rd.Zero | Parts | 18 | 2nd May 2004 04:00 PM |
| Page generated in 0.07947 seconds (77.12% PHP - 22.88% MySQL) with 10 queries |
