need help: clean gain switch
Old 23rd November 2007, 07:50 AM   #1
Alan Ang is offline Alan Ang  Singapore
Default need help: clean gain switch
Hi there,
I recently bought an amp over the internet and my installer tested it for me.
He commented that the gain switch is causing some noise when the knob is tuned. He then recommended that I get it cleaned at an electronics shop.
Does anyone here knows how I can clean the gain switch myself?
I am not an expert like you guys here but I did study electrical engg about 15 yrs ago. So you can be a little technical, I should still be able to follow...
Any help is more appreciated.
Thank you in advance.
Old 23rd November 2007, 09:05 AM   #2
Perry Babin is offline Perry Babin  United States
Any good contact cleaner will clean the pot. If you're going to use only one product, you 'don't' want something that says it leaves no residue. It will leave the pot dry and it will become noisy again.
If the pots have plastic housings, make sure you use products that are safe for use on plastics.
DeOxIt contact cleaners are very good but you need to use 2 products for good cleaning and long term protection. DeOxIt D5 is the cleaner I use. DeOxIt Gold is used for long term protection.
In some cases, the pots are damaged or worn and cleaning them will do little or nothing for the noise.
When you apply the cleaner, work the pot through it's entire range of travel until the pot is quiet.
need help: clean gain switchHide this!Advertise here!
Never try to switch 450V DC at 3A with a conventional mains switch... Eva Power Supplies 28 1st November 2006 09:24 AM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 01:30 PM
effects of gain selector switch in the feedback loop? scone Chip Amps 13 4th March 2005 06:22 PM
Gain Clone Entry Module? Corcom fuseable with switch. KevinLee Swap Meet 0 24th April 2003 02:34 AM
Using a momentary switch for main power switch? FullThrottleRic Parts 9 25th June 2002 08:23 PM
Copyright ©1999-2017 diyAudio
