Go Back   Home > Forums > General Interest > Car Audio
Old 21st November 2007, 02:24 AM   #1
spooney is offline spooney  United States
Default Replacement for a P50N06?
I've got an eclipse amp here with bad power supply fets.The ones in the amp are P50N06's.Is there any upgrade that could replace this part or perhaps a irf540n,irfz44n,or irfz46n? Only reason i ask about the IRF parts is because i have them all here.The originals are easy enough to get but i'd just as soon use something here if it will work.
Old 21st November 2007, 04:17 AM   #2
If they are ST transistors, and the gate resistors are less than 100 ohms, use the Z46s.
If the transistors are Motorola (on-semi) and the gate resistors are 100 ohms, use the Z44s.
The motorolas are rated for 43 amps. The STs are rated for 50 amps. Either the Z44 or the Z46 can replace the motorola part but I'd be concerned about using the Z46s with 100 ohm gate resistors.
Replacement LED DreadPirate Parts 11 14th November 2009 05:45 PM
Replacement amp for A-Bus? Greg911 Class D 0 16th November 2008 03:33 PM
MTX 5 ch pot replacement pk386 Parts 2 1st October 2006 05:32 AM
replacement cap for T-amp: How big? MEXXX Class D 5 10th December 2004 01:30 PM
Page generated in 0.06517 seconds (67.80% PHP - 32.20% MySQL) with 10 queries
