Go Back   Home > Forums > General Interest > Car Audio
Old 19th November 2007, 02:41 AM   #1
Send a message via AIM to JoeKnowsBasebal
Default sound sensitive LEDs
i'm a noob here. i know a little about electronics cause i used to install car audio/video/alarms, but i don't know all the equations for the electronics or anything like that. basically i know resistors and wire guages.
anyways... i want to wire a few (2 or 3) LEDs into my car that get brighter as i rev up my motor. i want to place them inside the hood scoop on a Camaro SS. I've wired LEDs in a car before, but i've never done a sound sensitive wiring. I want them to get brighter as the engine gets louder.
what are the parts i need and maybe a simple wiring diagram to help me out. just let me know the part names (like the device that recognizes louder or softer sounds) and maybe how much voltage i should have running through everything.
thanx in advance.
Old 19th November 2007, 03:13 AM   #2
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
If you are just wanting it to work off a mic look up lm3915, lm3916 Ic's. There are kits based on those chips that should do what you want.
Old 19th November 2007, 04:58 AM   #3
zigzagflux's Avatar
Send a message via AIM to zigzagflux
Would seem easier, simpler, and cheaper to use a tach signal, and use a frequency to voltage converter to light your LED's.
Mics are relatively expensive in comparision, and won't work very well under the hood, IMO.
Old 19th November 2007, 05:13 AM   #4
can i get those at a store like Radio Shack or would they have to be ordered off the internet?
Old 19th November 2007, 07:05 AM   #5
i'm still thinking about going the mic route. does anyone have a part number for a small mic that i could use with an LM3915 IC?
Old 19th November 2007, 11:39 AM   #6
The LM391x ICs are bar graph drivers and would be a good choice if you want to light more LEDs at higher volume. If you only need to make a group of LEDs brighter, you could use a mic to drive a simple amplifier circuit. The amplifier would make the LEDs brighter as the volume increased.
I don't know if this would work well without filtering. The mic would pick up any sound. Going down the highway, wind noise would make the LEDs light up.
Digikey has large selection of condenser mics that will work.
Touch sensitive sound modulation New2Electronics Everything Else 2 13th April 2009 04:28 PM
very sensitive speakers NED 209 Full Range 7 15th January 2008 06:54 AM
PCM1702 sensitive to ESD? klitgt Digital Source 11 14th February 2006 06:22 AM
Trade my blue LEDs for White LEDs CaliforniaBob Swap Meet 7 26th March 2004 08:28 AM
WTT: Blue LEDs for Red & Red/Green LEDs CaliforniaBob Swap Meet 2 9th June 2003 03:58 PM
Page generated in 0.10129 seconds (64.87% PHP - 35.13% MySQL) with 10 queries
