hi all, i need help.
I drive a toyota corolla, 2004 reg. i have a pioneer avic x1r head unit. i then have a sub and amp in boot, 6/9's on shelf, and all speakers re loaded but thats niether here or there really for my problem. when using the headunits amp there is no engine noise. when i start using the RCA loom there is engine noise on outputs coming straight out of the head unit. i have whittled it down to know its coming out of the unit and not picked up on the wires etc. i tried giving the unit a better ground, no luck. any ideas? cheers marc x |
#2 |
Disconnect the RCA cables from the head unit and measure the resistance from the shields of the RCA jacks on the head unit to the case of the head unit. The resistance should be ~0 ohms. If it's significantly more, the shield ground of the RCA jacks has opened.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
How far is the amplifier mounted from the head unit? I have frequently seen this problem when the signal coming out of the head unit had a signal ground that was tied to chassis ground. IOW, there is zero ohms resistance between the negative rca output and the chassis of the head unit. If this is the case and there is a long cable run from the head unit to the amp, you can have different ground potentials at the head unit and the amp. This results in a ground loop and noise that tracks with the alternator output - a whine that goes up and down in frequency with engine speed. Best way to solve this is with differential input and output line driver such as those marketed by David Navone and Audio Control.
Mark |
| engine noise - bad amp?? | Dan2 | Car Audio | 43 | 5th November 2008 10:26 AM |
| Engine noise | makaveli956 | Car Audio | 26 | 3rd June 2007 07:40 AM |
| Engine noise (tried almost everything) please help! | wally91chevrole | Car Audio | 34 | 26th February 2006 06:41 AM |
| engine noise HELP! | st33lownz | Car Audio | 6 | 4th November 2004 07:35 PM |
| noise in right speaker when engine on | crazyinjun | Car Audio | 13 | 7th May 2004 12:34 AM |
| Page generated in 0.06419 seconds (75.12% PHP - 24.88% MySQL) with 10 queries |
