Go Back   Home > Forums > General Interest > Car Audio
Old 9th November 2007, 01:00 AM   #1
Default Quick Amp Question
I just got this amp today with two blown IRFZ44N's in it replaced all 12 just to get smoke in the restistior next to the yellow box thing..not sure what that is. Took the yellow thing out amp functioned fine on my subs for ~30 min at full power with no problems. My question is Why was the resistor smoking and how bad is it to run the amp without that yellow thing in it? Sorry for the bad pics camera isnt that great.
PS yellow thing appears to be stamped either 7470nK 63 or T470nK 63
http://i227.photobucket.com/albums/d...P/DCP_3436.jpg
http://i227.photobucket.com/albums/d...P/DCP_3433.jpg
Old 9th November 2007, 02:02 AM   #2
The capacitor is a 470 nanoFarad 63 volt film capacitor with a ±10% tolerance. The 'T' is probably the manufacturer.
It appears that the capacitor is the wrong value. In all similar amps, the capacitor is a 47nF capacitor. A 470nF capacitor would allow much more of the square wave on the primary windings to pass through the resistor (instead of only passing the higher frequency ringing waveforms). This could cause the resistor to overheat. If you look at the other 3 snubber capacitors, you'll see that they're marked 473k 63.
Old 9th November 2007, 03:06 AM   #3
Yes Perry they are marked 473k 63 this amp I know has been repaired(hack job) before I bought it and I aslo thought that was the wrong piece. Were Can I purchase this piece? would a store IE radioshack carry one or could order one? and What else will work in that spot? just that one number?
Old 9th November 2007, 03:21 AM   #4
Virtually any film capacitor of the same value will work in that application.
47nF = 0.047uF
This should work well. Confirm that they're the correct size (physically) before ordering.
http://www.mouser.com/search/refine....7%2f100%2f5%09
Old 12th November 2007, 05:30 PM   #5
http://www.radioshack.com/product/in...entPage=family
Perry, Would these work for the application or no?
Old 12th November 2007, 07:11 PM   #6
Yes. The lead spacing may be wider than the others but other than that, they will work.
Quick question on the PP-C1 amp athos56 Tubes / Valves 13 20th October 2007 07:37 PM
Quick quick question ! guitvinny Pass Labs 6 7th February 2007 05:20 PM
Quick PCB question Piper Chip Amps 2 7th March 2005 11:59 AM
VERY quick question... Wyloch Multi-Way 2 3rd March 2005 05:34 PM
Page generated in 0.08101 seconds (74.17% PHP - 25.83% MySQL) with 10 queries
