Porting my sealed Enclosure
Old 6th November 2007, 11:31 PM   #1
KettermanJ is offline KettermanJ  United States
Default Porting my sealed Enclosure
I have a 1.0 cubic foot sealed box. If i wanted to port it to say 38Hz, how long would the port have to be and what diameter? im running a 10" MTX7500. thanks
-Josh
Old 6th November 2007, 11:45 PM   #2
spooney is offline spooney  United States
Its gonna be hard to fit a properly tuned port into a box that small.If you use a 3 inch diameter port(the minimum i would use) and are trying to acheive a 38 hz tuning your looking at an almost 11 inch long port IF your box has 1 cubic foot of airspace in it after port and speaker displacement.If your starting off with 1 cube of airspace your not gonna be anywhere near 1 cube after you get that port and sub in there.Also that 3 inch diameter port should have at least 3 inches of space behind it to keep the air flowing smoothly.Unless your putting a portion or all of that port outside the box its gonna be hard to acheive what your after.
Porting my sealed EnclosureHide this!Advertise here!
Jordans in sealed enclosure? billnchristy Full Range 3 19th November 2006 04:23 PM
Sealed Enclosure Driver Madmike2 Subwoofers 2 19th May 2005 12:53 AM
Small sealed enclosure Ddeele Subwoofers 15 20th January 2005 08:50 AM
Porting a fullrange enclosure? HiggityHank Full Range 20 10th December 2003 07:04 PM
porting a sealed sub, yes or no MbayAQ Multi-Way 4 29th December 2002 03:30 PM
