Amp thuds when turned on and off fast
Old 6th November 2007, 09:31 PM   #1
audiobahnkid592 is offline audiobahnkid592  United States
Default Amp thuds when turned on and off fast
If my amp is on then you cycle the key off then right back on it puts out a very large thud into my subs. Would this be caused by capacitors being bad in the amp? And its only my subwoofer amp doing this not any of my speaker amps.
Old 7th November 2007, 12:03 AM   #2
Perry Babin is offline Perry Babin  United States
If the remote turn-on for the amp is switched with the key (as it should be), there's something wrong with the muting circuit in the amplifier.
Old 7th November 2007, 12:26 AM   #3
Thanks Perry, but if i wait about 3 seconds before re cycling the key it does not make any noise. The amp is the audiobahn A18001DT amp that I fixed and has done this ever since I have owned it. If it is the muting circuit were do I look?
Old 7th November 2007, 12:47 AM   #4
The muting circuit has a delay that's determined by a capacitor and a resistor. When the voltage on the capacitor reaches a certain point (2.5v?), the muting is defeated and the driver board switches on.
To engage the muting quickly when the amp is switched off, the the capacitor is discharged through a diode.
For some reason, yours doesn't seem to be discharging quickly enough. There could be several reasons.
Since these amps typically have a long turn on delay, I'm guessing that this only happens when you're listening to it with the engine off and then quickly go from acc to start while the amp is on. If that's the case, I'd suggest leaving as it is. There's a chance to do much more damage if you make a mistake while working on the amp.
Old 7th November 2007, 01:37 AM   #5
If you say leave it I will but is it bad for my subs and or amp to have that happen?
Old 7th November 2007, 03:57 AM   #6
It depends on how bad the thump is.
If it only does it after you've been listening to it with the engine off, turn the key from acc to off and wait 3 seconds before starting the engine.
Amp thuds when turned on and off fastHide this!Advertise here!
hum on pre-amp when volume is turned up phrarod Tubes / Valves 6 14th June 2009 07:11 PM
Pop when amp is turned off boostin1989 Solid State 6 10th October 2006 05:10 PM
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 10:00 PM
Leach amp has hum only when turned off! kiwi_abroad Solid State 12 26th March 2004 04:17 PM
Hum when volume is turned down miguel2 Tubes / Valves 34 18th March 2003 07:51 PM
