I have a set of 12" old kickers from the mid 80's, Not solobaric. will a 2.0 box be enough. Only be running around 150 watts to each. 85% rock music. thanks.
#2 |
2 cubic feet should be work.If I remember correctly the recommended enclosure volume for old school kickers was 1.75 cubic feet per sub
#3 |
how would they sound? I don't have much room.
#4 |
If your going to use a 2 cubic foot box for both I would definitely make sure you stuff it with polyfill to account for the lost volume.I believe the rule of thumb is 1 pound of polyfill per cubic foot of volume.It won't sound horrible but you may not get the intended effect.Personally I'd go with one sub in the proper enclosure over two in the wrong one.
#5 |
I am running 2- 10" subs in a 1.70 box now. what is I put a new front on that box (1.70) and run 1-12" will 1- 12 sound better that 2- 10's
#6 |
What do you mean by sound better?Do you mean louder or actual better sound quality? If the two tens are in the proper size enclosure and are of decent quality then I don't really see one 12 outdoing them in output unless maybe you have a couple of cheap 10s and a monster 12 inch sub with a lot of power behind it.
#7 |
The 10's are not high end. they are fosgate XLC svc subs. they bump pretty good. make my nose tickel! ha, ha, just was wondering about the 12 I have, if it would be worth it.
#8 |
If they are from the 80's, they definately won't sound right with 1 cubic foot each. Better to run one ported in the 2 cubic foot box and do some good calculating, than both in too small of a sealed box.
Don't worry... you can always turn the gain down! |
#9 |
thank you for the help, new to this and lookin for tips and anwsers. thanks again. No reply nessacery.
#10 |
A lot of the subs from the 80s are free air and don't do small boxes that well. See if you can look up the T&S parameters for them. If you can then plug into a sub box program and check the output curve...compare it to something you use or have heard.
| Where did you go to school? | BERENO | The Lounge | 7 | 12th April 2009 09:44 PM |
| Old School F5 by ZM | Zen Mod | Pass Labs | 77 | 27th January 2009 08:03 PM |
| Old School favorites go bad while I'm out of school...HELP! | HayaBuddha | Car Audio | 5 | 26th March 2007 05:20 AM |
| Old School Top 5 | mgibson | Solid State | 7 | 5th July 2006 05:18 PM |
| old school fun | chainenoble | Multi-Way | 0 | 21st May 2006 06:23 PM |
| Page generated in 0.10835 seconds (75.27% PHP - 24.73% MySQL) with 10 queries |
