Hey guys,
Got a Rockford Fosgate Punch 100a2 amp. (25Wx2 4ohms,and 50Wx2 at 2ohms.) I opened it up to check it out after a recent drop,and all seems fine,and the amp works okay... While it was open,I noticed that the SMPS FET's have been replaced,and a small jumper added,to replace a fried trace.. No biggie,the repair work looks good,and the amp works,so. The filter caps (post-SMPS) are rather small though,at 330uf each. (I'm thinking it'll replace them with some 1000uf caps.) Also,I noticed that the SMPS transformer has a sticker around it,with the writing "2032A 100.2 cbs(at)theriver.com" Is this some kind of replacment/aftermarket/custom transformer? (maybe the old one shorted,and fried the original FET's?) The output transistors/FET's (haven't taken the mounting clamp off to check the PN's yet.) appear stock,with the factory (wave?) soldering,so they haven't been replaced or fiddled with... just the SMPS FET's.. I was just pondering,maybe some of this gives a clue as to who fixed it previously? (Whoever you are,it's still working just fine,good job!) One last question,Since this amp says it's okay to run 2ohm stereo,I would assume a 4ohm load,bridged,would be okay? |
#2 |
I've seen those bands on several amps. I have some photos of a 100a2 with the band around the transformer (can't read it from the angle though). The connections on the transformers looked like they were flow soldered so I believe they were OEM.
4 ohms bridged is a safe load.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
| Mysterious OPT winding tap | Klimon | Tubes / Valves | 8 | 15th May 2009 10:06 AM |
| Mysterious runaway output tube | trombone | Tubes / Valves | 8 | 26th March 2005 08:03 PM |
| Mysterious Output Transformer.... | zxx123 | Tubes / Valves | 6 | 12th January 2005 09:05 PM |
| mysterious magnet wire | jonathan3233 | Parts | 4 | 11th October 2004 02:39 AM |
| mysterious Zen woofer selection | supa-roo | Pass Labs | 2 | 19th April 2003 08:51 PM |
| Page generated in 0.06983 seconds (82.15% PHP - 17.85% MySQL) with 10 queries |
