Go Back   Home > Forums > General Interest > Car Audio
Old 21st November 2007, 05:57 AM   #41
shagone is offline shagone  United States
that may be true. i'm not sure how they would do in the automotive environment unless you mounted them in a metal case for shielding or lined the plastic case with copper or aluminum foil and used good shielded signal cables away from factory harnesses and power wires.
if i was in your shoes i would simply start with a full speaker upgrade powered off of the factory amp and see if that helps. it should! and go from there with new amps and signal proccesors in the future. i'm thinking that the speakers are probably your weakest link at this point.
Old 21st November 2007, 06:08 AM   #42
phrarod is offline phrarod  United States
I came to the same decision. I'm ordering the speakers tomorrow. I'll update you. Since there's zero highs right now it can't be any worse and hopefully a lot better until I figure out a amp solution.
DIY mini speaker project Driver_King Multi-Way 27 1st December 2008 06:30 PM
Anyone get a line out from a 07 Mini Cooper? phrarod Car Audio 0 14th June 2008 04:39 PM
Cooper foil, paper oil capasitpors nafanja Vendor's Bazaar 1 9th May 2008 10:41 AM
Advice on new project- Mini-A w/ JFET or F4? winslow Pass Labs 5 18th January 2008 01:05 AM
Any mini speaker plans happyb Multi-Way 7 27th March 2006 08:12 AM
Page generated in 0.06949 seconds (71.02% PHP - 28.98% MySQL) with 10 queries
