Go Back   Home > Forums > General Interest > Car Audio
Old 18th October 2007, 03:58 PM   #1
bega_83 is offline bega_83  Bosnia and Herzegovina
bega_83's Avatar
Send a message via Yahoo to bega_83
Default Need some help with Sony CDX-R3350
I would like to have your opinion on this one: my player switches off after about an hour or so of playing, but it turn on automatically right away and than plays on...
Could it be because of overheat or sth else??
I use to have a 1000w(peak power) amp in the trunk and have put another battery in the trunk to provide more power (dunno if that was a bad idea, so far it worked just fine-alt recharged well both of them...with a litlle help of course). The amp had the same problem though, but only when playin bridged. That's why i took it out, but the problem still occurs.
Any ideas, suggestions?
Old 20th October 2007, 04:05 PM   #2
iUSERTLO72p's Avatar
Default Interesting
Could be overheating. Wire it up on a seperate battery indoors, or another car.
I have a battery in the trunk/boot and I charge it up every once in a while with a battery charger on the mains. Do you split charge? I wander if your wiring is causing problems.
Cheers
iUSERTLO72p
Old 20th October 2007, 04:11 PM   #3
bega_83's Avatar
let's see if i got ur question right... i do recharge battery like once a week as well.
both batts are connected by the +pole, negative of the secondary bat is on the chassis of the car.
did i do it wrong?
Sony CDP-337ESD v Sony CDP-X33ES which is best? eldarvanyar Digital Source 0 10th January 2008 11:04 AM
Sony CDP-711... DoomPixie Digital Source 9 16th May 2007 01:33 PM
Sony PSX-800 fmak Analogue Source 0 18th September 2003 03:48 PM
Page generated in 0.07637 seconds (75.74% PHP - 24.26% MySQL) with 10 queries
